sub cuts out....
Old Jan 8, 2008 | 07:58 PM
hotstartup's Avatar
sub cuts out....
today my stock bose system was acting a little wierdly, the sub was randomly cutting out (every other speaker worked fine).. if i turned it off and turned it back on a few mins later everthing is normal. any ideas?
Old Jan 8, 2008 | 08:53 PM
MaXiM@KiD's Avatar
MaXXiN
Check the fuse
Old Jan 8, 2008 | 09:10 PM
DrunkieTheBear's Avatar
Turbo'd Saab
which fuse and where? my sub is doing the samething, it started yesterday.
Old Jan 8, 2008 | 11:07 PM
hotstartup's Avatar
fuse woudlnt randomly cut then get ok again after shutting deck off and replaying it. right?
Old Jan 8, 2008 | 11:42 PM
impact'sa33's Avatar
Originally Posted by MaXiM@KiD
Check the fuse
Old Jan 9, 2008 | 03:55 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
it cannot be a fuse, check your wiring form the sub to the crossover....... that's where your problem is.... I move the cables a little bit and the sub comes back to life
Old Jan 9, 2008 | 05:34 AM
phatboislim's Avatar
maybe i should check my fuse too...but my sub comes on when it wants to...i really hate to have to take out my H/U, take it apart and check the ribbon inside of it
Old Jan 9, 2008 | 09:59 AM
hotstartup's Avatar
i doubt this problem has to do with the ribbon....souds more electrical to me. id do wat lantar said first
Old Jan 9, 2008 | 10:15 AM
Pearl93VE's Avatar
I can has?
Can only be a few things...
Check your ground, make sure it's fully bolted down, and has a secure connection to the stock amp/ whatever it runs to.
Old Jan 9, 2008 | 04:37 PM
SilverGLE's Avatar
I'm watching you, boy...
Check the crossover... It's the little black box (usually under some gray foam). If you don't mind the turn-on "thump," disconnect the box entirely at the closest connectors. That's most likely your problem.
Old Jan 9, 2008 | 05:35 PM
choiiiiiiiiiii's Avatar
THERE'S AN AUDIO THREAD!?!?
ALL of the answers happen to be there....
Old Jan 9, 2008 | 05:37 PM
kroze's Avatar
could it be the stock amp overheating? or going bad altogether?
Old Jan 9, 2008 | 09:34 PM
hotstartup's Avatar
in the trunk?
Old Jan 9, 2008 | 10:56 PM
SilverGLE's Avatar
^ Yup. It's connected to the amp, which is bolted directly underneath the sub.
SilverGLE's Avatar
Old Jan 9, 2008 | 11:18 PM
drewdub's Avatar
max20's
i installed my subs and amps into my 02 maxima and it was doing the same thing . I checked everything out i couldn't figure it out . So i called several stereo stores and the said that you have to re-wire and get new speakers all the way around so took my stuff out it sucked
Old Jan 9, 2008 | 11:40 PM
hotstartup's Avatar
the amp is to the right of the sub! well atleast on my 03. i will try to find he cross overs all i saw was the sub and the amp next to it, ith some wirining behind the carpet (didnt explore it too much though)
Old Jan 10, 2008 | 12:20 AM
Lontar1's Avatar
check the wire harness....
Old Jan 10, 2008 | 05:32 AM
kukx30de's Avatar
its not the wires, its the amp circuit itself!
look at http://carstereohelp.com/
I got the fix done from them for my 01 sub. No issues anymore.
And, i found this on the internet not through the audio forum here. All the information on the audio forum is how to upgrade the music system not how to maintain the stock system.
The common consesus on audio forum is that the stock radio sucks... while that maybe the case, the factory bose is really better than some other premium audio systems i have heard, e.g. my e46 harmon kardon! which has been dramatically modified now
good luck!
Old Jan 10, 2008 | 10:00 AM
hotstartup's Avatar
good luck!
how much did it cost? any clue what the problemwas and if it can be done at home?
your absolutely write about the info on the audio forums, I however love the look of the stock system, aftermarket stuff sticks out too much, and kiinda ruins the interior in my opinion.
Old Jan 10, 2008 | 10:13 AM
Iceman420's Avatar
(insert witty one liner)
While I agree the stock unit does look nice, a double din screen looks really good as well. When I swap the stock blows HU out that's what I'll be doing.
GL with your sub problem.
Old Jan 10, 2008 | 12:50 PM
kukx30de's Avatar
I paid about 120... and they have a lifetime warranty on the repair as long as you own the car.
I dont know what they did but i am sure there was a circuit fault that was fixed.i.e. some components replaced.
Old Jan 11, 2008 | 12:53 AM
hotstartup's Avatar
iceman i would love to see pics if the DD once u get it in. The sub prblem seems to have fixed itself for now....
Old Jan 15, 2008 | 09:05 AM
did u just take the amp out and ship it to them?
Old Jan 15, 2008 | 04:17 PM
raymond3414's Avatar
I have a big amp and it was thirsty for power and have had the same problem. It ended up being that my voltage would drop too low and I had a thermal protector on my amp. and it would always cut my amp out. I ended up getting a optima battery and a xstatic cap. And then I had all the juices I needed for my JL 13w.
Old Jan 16, 2008 | 05:33 AM
thermal protector...to protect it from overheating right?? it seems that my sub only plays in the morning...when its cold....
Old Jan 16, 2008 | 09:14 AM
spark plugs.'s Avatar
Hi, I drive a Maxima.
Check the fuse
fuse would have nothing to do with that problem.
Old Jan 16, 2008 | 08:46 PM
Snypa's Avatar
not fuse at all. sounds like some wiring probs/connection or just simple overheating amp.
Old Jan 17, 2008 | 06:30 AM
BigPete's Avatar
Incognito
Old Jan 17, 2008 | 07:41 AM
essential1's Avatar
My axles cry for mercy...
I have the same exact problem. I'm not sure what the technical name of the part is, (i know nothing about car audio) but if you look in the trunk directly under the stock sub, there's a black cover labeld "SPEAKER ASSY, REAR". Inside that, there's a metal square/rectangular part that is labeld "PCB ASSY 100W QR". When it's plugged in and I tap on it, the sub cuts in/out. I doubt it's the wiring because i jiggled the hell out of the wires and got nothing.
I'm almost positive (in my situation atleast) if this part was replaced the problem will go away. My car is an 01 I30 by the way.
Old Feb 3, 2008 | 08:45 PM
MaDMvD's Avatar
Same problem in my girlfriend's '01 GLE. The problem lies in the wire harness that goes from the sub to the amp. If you remove it and take all the foam crap off it, it's part # 02A93P809UN. Replacing it will fix the problem, but I wonder if you could just replace one of the resistors or something...
Old Feb 5, 2008 | 05:47 AM
cfd308's Avatar
CD Cuts out??
Hey Guys, sorry for posting this here but Im having trouble posting a new thread.
OK so here's my problem.
03 GLE, Stock everything,
My radio works fine all speakers work no prob. The CD doesnt however,
Seems like when the cd is playing its only coming out of the passenger side front and rear speakers as well as the driver rear. If the brake is applied or hitting a bump it all of a sudden sounds again. I tried looking under behind the radio and as close to the pillar speaker as possible.
any help would be greatly appreciated, thank you!
Pinny
Cfd308@msn.com
James92SE
142
Jan 2, 2024 09:23 AM
magiconthetire
Oct 26, 2015 09:03 PM
RealityCheck
Oct 2, 2015 06:34 PM
Taino14
Sep 24, 2015 02:51 PM
