sirius install in 4th gen
Old Jan 22, 2008 | 02:58 PM
05AltimaSER's Avatar
I just finished installing a sportster 4 in the wife's 98 max SE with BOSE. I used the integraded fm transmitter and it sounds crappy. You can hear static. I did not use the fm extender antenna.
I want to know how others had wired the sirius/xm with the factory BOSE headunit. I had the antenna adapter but the antenna connector of the Bose is different(with two prongs)
thanks
Old Jan 22, 2008 | 04:08 PM
BK1's Avatar
BK1
Hello
You can try a cassette adapter.
Old Jan 22, 2008 | 07:39 PM
mendon99's Avatar
tastey wheat
try using the FM extender antenna then. iirc, they're terrible without them. to be honest, FM transmitters suck period.
You can however get a direct FM adapter, Directed makes a good one (local car audio shops should have them), and this breaks open your antenna, works signficantly better.
Old Jan 23, 2008 | 09:29 AM
I have the FM adapter but the 98 BOSE antenna lead is not a usual antenna lead. It has 2 prongs.
I will try to install the FM extender antenna and mount it in the rear.
thanks for the info!
Matt93SE
May 24, 2019 02:58 PM
Cotozic
Jun 28, 2017 08:01 PM
Finkle
Sep 27, 2015 09:53 PM
ef9
Aug 27, 2015 07:21 AM
MikesChevelle
Aug 6, 2015 11:36 AM
