small inline audio filter amplifer thingy?
Old Feb 8, 2008 | 10:56 PM
Niku-Sama's Avatar
alright this isnt really maxima related but i figured its the best place for this.
i was wondering if there was any sort of inline filter or amplifer thing, basicly to get better sound or keep interference out, that i can cheaply make for speakers?
i'm planning on putting some infiniti kappas in my 280 (that i pulled from my maxima) and i pretty much have to wire the WHOLE radio from scratch and i just want to cover some things so i just want to get good sound out of these any way.
its one of those thing "while i am at it i should..."
Old Feb 9, 2008 | 07:57 AM
djfrestyl's Avatar
Suspension Yoda
My noobie-sense is tingling.
Proper wiring and a real amplifier.
Old Feb 9, 2008 | 11:55 AM
Niku-Sama's Avatar
doesent necessarily have to be an inline amp it can be a filter of sorts aswell.
i figure since i am wiring them up for RCA plugs i might as well
Old Feb 9, 2008 | 02:44 PM
djfrestyl's Avatar
Suspension Yoda
No need for filters either.
My previous statement holds true...proper wiring and you won't need filters.
Old Feb 10, 2008 | 01:12 PM
Niku-Sama's Avatar
ok well thanks for the lack of help.
i still get feed back things are properly grounded and power wires run a different way than speaker wires.
Old Feb 10, 2008 | 01:48 PM
Pearl96Max's Avatar
I tend to get a bit irritable
There is no magical inline filter. If this is what your thinking, then you need to reevaluate the situation. What was posted above IS help, if you dont want to follow it, then say so. Your comments of 'thatnks for the lack of help' arent needed. Help was provided and you chose to continue thinking that there is an magical device to fix your issue. Simple fact is that there is not and you should recheck your wiring ... wire going in a 'different way' will result in nothing helpful.
Old Feb 10, 2008 | 01:55 PM
WillMax01's Avatar
Uhhh...don't get it. The point of an amp is to eliminate distortion as well as boost speaker power...
Old Feb 10, 2008 | 11:23 PM
Niku-Sama's Avatar
this comment wasnt of help either
because it is properly wired, i made damn sure of that after i bought the car from the previous owner and it took a lot of hard freakin work.
an AMP or a FILTER
either way it doesent matter i have recived what i need elsewhere.
lock it pease
Old Feb 11, 2008 | 04:30 AM
djfrestyl's Avatar
Suspension Yoda
Bottom line, if you're getting whine/noise/interference of any sort, it's NOT properly wired, or your components are having issues.
If you want an apology, sorry for being blunt, but my information and advice remains standing.
my03maxima
Jul 28, 2024 07:40 AM
Fbana41
Aug 29, 2016 12:18 PM
Justin Kroll
Oct 1, 2015 07:03 PM
