Assistance Required: HU Not Functioning
Old Mar 10, 2008 | 03:27 PM
resurrectedmax's Avatar
enthuzed.........
So my Bose deck died......aka wont turn on anymore....Before she died, it would temporarily turn on and off based on the level of sound. I cranked it to the roof one time and that was the end of my sound.
Bought an AVIC-D3X, installed with the Metra harness (70-7551) ....did not work. Found another power source (power outlet) to hook it up temporarily so that the NAV works.
My installer tells me that there isn't anything coming through the stock radio harness. No power, speakers don't work, nothing.
We checked all of the fuses and everything is proper except for the fact that there was a 20A fuse where in the fuse box, where it states that a 15A should be present. Also my horn stopped working, it also has a 20A were a 15A should be present.
Vehicle is an 01 SE 5 Spd.
Any insight would be amazing. Driving in silence isn't the best thing in the world.
Appreciate any assistance.
Best regards,
Raakesh
Old Mar 10, 2008 | 04:42 PM
pikers's Avatar
Is there any main fuse under the hood that links to this? It seems that with a new HU the possibility of frying the factory went by the wayside, since the new one doesn't work either.
If you have the Bose speakers (I'm assuming so), the question then becomes are these fused individually elsewhere (since they're amplified individually)--and is this tied to the horn in some wacky way?
Maybe not much help, just giving you some possible paths to explore.
Old Mar 10, 2008 | 11:07 PM
machinehead's Avatar
Time to pull all of that bose junk out and replace it anyways!
Old Mar 11, 2008 | 08:56 AM
enthuzed.........
Thanks for your reply gents.
There is a main fuse, its fine. I don't think that they're tied to the horn, but they are located right beside each other on the fuse box.
Do you think that the amp supplies everything to all of these wires? i think not. Seems as though the wiring diagram in the FSM states that power goes from the battery to the amp, sub and deck separately.
There is this underlying issue that i'd like resolved prior to taking that step. My horn still doesn't work and as mush as i'd like to replace everything with awesomeness, i cant right now...
Old Mar 19, 2008 | 08:40 PM
brnxv8's Avatar
i replied to some other thread about the AVIC D3X package but ill respond the same here too. i have installed the D3x package myself on my 07. it took me a while but it was well worth it. anyway in responce to ur issue my suggestion is to replace all of your bose equipment speakers an all, each speaker is indiviually amplified. i would remove it all the replace the speakers, the stock bose system is over rated anyway. the horn has a fuse i believe but how it ties inot the system i have no idea. i wish i could be of more assistance. if anyone else has any questions such as the proper bypass (not adding a switch) or tapping the reverse gear or VSS in there 07's feel free to PM me.
Old Mar 20, 2008 | 06:48 AM
enthuzed.........
nice plug.
and i reiterate: There is this underlying issue that i'd like resolved prior to taking that step.
i currently have about 5 people trying to source an engine room harness for me. pretty sure some wires have corroded into each other
thanks for your help thus far org.
gavin68
Sep 18, 2021 12:36 PM
homewrecker
Sep 23, 2015 03:41 AM
coasterswim
Sep 2, 2015 07:43 AM
rbaker100
Aug 28, 2015 08:11 PM
Maxinesdaddy
Aug 21, 2015 11:43 PM
