Amplifier Ground Point
Old Mar 12, 2008 | 05:52 AM
amomaxima's Avatar
Where are you guys grounding your amps.
Trying to decide which is the best place.
Any Ideas and suggestions.
i used to have ti run to a bolt i put through the trunk right behind the driver taillight. but it took way to much effort.
I want something closer to the back seat.
Old Mar 12, 2008 | 06:43 AM
nismos14's Avatar
§è~® f®ÈÄk
Seat belt bolt.
Old Mar 12, 2008 | 06:44 AM
amomaxima's Avatar
Originally Posted by nismos14
Seat belt bolt.
are you getting any hum
you put in under it so the seat belt hold the ground loop down right
Old Mar 12, 2008 | 08:17 AM
DcMaN's Avatar
you have to sand the paint off the seat belt bolt + sand down the area where the bolt goes.
Old Mar 12, 2008 | 08:28 AM
AscendantMax's Avatar
grounded mine in the spare tire well.
Old Mar 12, 2008 | 09:08 AM
travmaximas1998's Avatar
+1
Old Mar 12, 2008 | 11:53 AM
amomaxima's Avatar
Originally Posted by travmaximas1998
+1
yeah i think i will go there
are you talking where the seat belt buckle attaches or the part on the next to the fuel pump where the buckle clip is
Old Mar 13, 2008 | 06:00 PM
Afronaut's Avatar
Active procrastinator
I used the seat belt bolt also and I have had no issues. I used one of the bolts for the center belt.
Old Mar 13, 2008 | 08:12 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Seats belt bolts are generally covered in locktite, so not the best option, but not the worst. 50/50 odds with it not having any problems.
Old Mar 14, 2008 | 08:13 AM
amomaxima's Avatar
i used the bolt that the back of the seat attached to in the trunk off to the drivers side
hooked it all up and ZERO hum
perfection
ill post some pics
but i am happy with it
Old Jun 4, 2008 | 05:04 PM
VQuick's Avatar
Chassis Freak
I've got a small amp going under the passenger seat. Is there any problem grounding it and the headunit to the BCM ground under the center console? I figure it's got to be a decent ground already; I just don't want to risk messing up the BCM somehow.
Old Jun 5, 2008 | 03:29 PM
WhiteA32's Avatar
I grounded mine to the Seat itself. There are 4 bolts that bolt the seat down to the chassis and I used that, just sand it down and wala wala bing bang
Old Jun 5, 2008 | 09:57 PM
Coolsaber57's Avatar
I've got mine in the trunk, so I grounded it to a strut mount bolt. Kinda a pain to get back there, but it works nicely.
Old Jun 13, 2008 | 01:13 PM
CarAudioHelp's Avatar
Pearl96max is right about junk covering the seat belt bolt sometimes. Perry has a good page on battery and amp grounds here:
http://www.bcae1.com/battgrnd.htm
Old Jun 13, 2008 | 09:23 PM
maxprivate's Avatar
Black Lion
Is the braided ground strap to the vehicle chassis necessary when upgrading your system? or Is just the short ground wire enough from the neg of the battery to the chassis? I know it says to use both but Im just curious to what others are doing.
Old Jun 14, 2008 | 09:17 AM
filtor1's Avatar
Man I love that site! I wish everyone would start their search there.
Old Jun 14, 2008 | 09:22 AM
nismos14's Avatar
§è~® f®ÈÄk
Only noobs ground there amps anymore.
Old Jun 14, 2008 | 10:41 AM
ICEMAN76's Avatar
So what do you do with yours?
Old Jun 14, 2008 | 10:58 AM
slickrick's Avatar
I agree...
Old Jun 15, 2008 | 09:19 AM
nismos14's Avatar
§è~® f®ÈÄk
If you don't know, I won't explain. It's just too complicated.
Old Jun 15, 2008 | 11:16 AM
1996blackmax's Avatar
I grounded mine to one of the bolts on the front seats as my amps are under there. Just made sure that I did a good job sanding down the contact points......guess I am still a noob
Old Jun 15, 2008 | 11:38 AM
VQuick's Avatar
Chassis Freak
LMAO
Old Jun 15, 2008 | 11:54 AM
nismos14's Avatar
§è~® f®ÈÄk
Juan! Whats up man??
Yes you are a noobskate.
Old Jun 15, 2008 | 11:55 AM
ICEMAN76's Avatar
That's some FU repugnant $H!t. Is there somewhere we can go look it up? So that the rest of us can be educated and informed like you.
Old Jun 15, 2008 | 11:59 AM
nismos14's Avatar
§è~® f®ÈÄk
Yea www.wikipedia.com....................
Old Jun 15, 2008 | 12:09 PM
Pearl96Max's Avatar
Says the guy with 4Awg going into 0Awg, then for ground a distro block to go to one amp !
Old Jun 15, 2008 | 02:23 PM
Same ole good stuff....been pretty busy with work and the family as of late.
Old Jun 15, 2008 | 02:26 PM
nismos14's Avatar
§è~® f®ÈÄk
That fat raptor wire is really 4 awg didn't have any connecters to fit the bolt on the ground, that was the only alternative at the time
Old Jun 15, 2008 | 02:37 PM
Pearl96Max's Avatar
blah,blah blah ..
Old Jun 15, 2008 | 05:58 PM
ICEMAN76's Avatar
Thanks, I guess. I can only hope to be as knowledgeable as you one day.
gigabyte
Jan 6, 2017 06:05 PM
magiconthetire
Oct 26, 2015 09:03 PM
sliptap
Sep 30, 2015 05:57 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
