Interesting problem
Old Mar 15, 2008 | 02:04 PM
20SE00's Avatar
Interesting problem
The subs hit just fine, but i noticed when i pop the trunk with the music still going and stay in the car, even with the trunk just popped and not all the way open, it sounds like the subs are hitting much harder
any idea what this means? or how i can get them to sound like that all the time?
i had thought maybe i need a bigger box.. or maybe i need to put port holes in the box? it is sealed
really what im asking is why they sound different with the trunk open.. obviously because there is more air pressure on the box with the trunk open.. but that shouldnt effect a sealed box right?
Old Mar 15, 2008 | 02:11 PM
AscendantMax's Avatar
well the bass isn't restricted when you're literally facing the subs with the trunk open.
port the subs (properly that is...you can't just drill holes into the box) and it will be much louder.
Old Mar 15, 2008 | 02:13 PM
Thanatos's Avatar
yeh if your subs cant move the air they are suppost to move you are losing your bass. they have to be able to "move air". if they are restricted. your sound is restricted. so what kind of set-up do you have. subs/box. bigger isnt always better.
Old Mar 15, 2008 | 02:59 PM
20SE00's Avatar
uhh trying to remember off hand real quick, dont have time to check right now
2 kenwood 12" 1200w
800w pioneer amp wired in parallel
custom built box with subs facing out, toward the back seats, the volume is smaller than recommended i know that, but not by too much.. i didnt have enough material to make the box any bigger, it's sealed
i can get more specifics later, on the way out the door right now
Old Mar 15, 2008 | 03:16 PM
eh, just keep in mind ported boxes will be a bit bigger than a sealed box. so if you're willing to give up more trunk space and gain output, a ported box will be ideal for you.
but, if you don't want to give up the room, try to make the sealed box a bit larger to be more efficient. your lower octaves will be more noticebale as well.
Old Mar 15, 2008 | 03:22 PM
kpr10is's Avatar
You just solved this yourself. Face your subs towards the rear of the car. Problem solved.
Old Mar 15, 2008 | 09:12 PM
20SE00's Avatar
sorry didnt specify, i dont really want to change anything in terms of new equipment, just wondering if there was anything i could do to my current set up
thanks, i'll give that a shot
Old Mar 16, 2008 | 10:41 AM
filtor1's Avatar
By facing the subs forward without sealing off the trunk, you are creating a large amount of cancellation due to the waves bouncing around in the trunk. Facing the subs to the rear of the car "should" resolve the issue.
Old Mar 16, 2008 | 12:54 PM
20SE00's Avatar
i just flipped the box around and there is definitely a noticeable positive difference in sound, thanks guys
they still hit harder with the trunk popped, but i figure thats because the box is smaller than recommended.
Old Mar 16, 2008 | 02:22 PM
nismos14's Avatar
§è~® f®ÈÄk
Remove any rear deck speakrs you have and let some of that bass in the cabin, should help a wee bit.
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
03VQMAX
Nov 10, 2015 03:39 PM
jc53
Oct 6, 2015 06:00 AM
slowlifer
Sep 8, 2015 05:53 AM
