adding bose to non bose
Old Apr 6, 2008 | 08:23 AM
Jvlouse's Avatar
Hi everyone... well i basically have a 95 max gxe that i almost full converted to a 97-99 max interior and exterior...
My wiring is for obviously non bose but i just purchased some bose speakers to fully bring my speakers back to gle stock.
Right now i have a dvd headunit in and sucky sony speakers... i dont want my system to be extremely loud but i know the bose will sound better than the sonys.
The bose speakers in the front have a connector with 6 pins and the rears have a connector with four pins. Right now i have just two wires that connect to a speaker.
Now i opened up the front bose speakers and see that theres two wires that come out of both the positive and negative terminals on the speaker. then 1 of each of those wires from each side goes into the amp and the other 2 go straight to the connector.
The 2 other wires that are left go into the amp but come out with 4 wires now instead of two and they are different colors.
the two wires that go from the speaker straight to the connector i believe are for the tweeters.
Now my question... i have a positive and negative wires for each speakers that connect to the head unit. is there anyway i could connect the 4 wires to the 2 wires i have now... what are the extra 2 wires for...?
Old Apr 6, 2008 | 11:21 AM
nismos14's Avatar
§è~® f®ÈÄk
You are really wasting your time man. You will prob be less happy with the stock bose in there.
Old May 21, 2008 | 02:36 PM
sampimpinthug's Avatar
I am in a similar situation. I have a 2000 maxima and my stock cd player just gave up on me. So i ordered a bose cd player from ebay thinking that it would be cool to have a bose and because it was cheaper but appareantly I read somewhere that the bose one does come with preamped watts so it wouldn't give power to my speakers and I would need an amp for that.
So if someone could clarify this with me then it would be great. Thanks!
Old May 21, 2008 | 05:13 PM
chinaonnitrous1's Avatar
Its like pouring salt on a wound....
Old May 21, 2008 | 09:24 PM
so i am guessing the response is a no? and do maximas need factory codes for their radio/cd players?
Old May 21, 2008 | 09:27 PM
also is there any special adapter needed or a fitting kit needed for bose? or is it plug and play?
Thanks a lot for prompt replies.
Old May 21, 2008 | 09:47 PM
If you have non bose car..
You add Bose stereo...You need Bose amp...Bose speakers...and probably the Bose harness from the radio all oover the car.
Not worth it.
Old May 22, 2008 | 08:39 AM
Ah crap! So what should i do with the bose lying at home? are you sure about this information?
Old May 22, 2008 | 10:11 AM
Yes I'm sure. I've had a 2k2 with bose, and I installed for about 5 years.
Keep it, sell it on here, Bose seems to break often anyway
Old May 22, 2008 | 02:12 PM
if i get a non bose cd player from the junk yard or something. do I need to get the vehicle's information such as vin number and stuff for a radio code or maxima cd players dont have codes.
Old May 22, 2008 | 06:47 PM
Also, can we swap a 2000 non-bose deck with the part number of PN-2280D A and td code of CN628 with a 2001 deck with the part number PN-2415D A and td code of CNB88, even though they look exactly the same and there were no major differences between 2000 and 2001.
Old May 22, 2008 | 07:11 PM
If its non-bose, it will work. The harnesss will be the same.
Look for yourself. Nissan only has 2 versions of harnesses, one for like the early 90's and ones for 96+ or something.
If the harness fits, it will fire up. All Nissan NON Bose stereos are fine to use on a Non Bose nissan system.
Old May 27, 2008 | 11:17 AM
is there some kind of security code on nissan non bose systems?
Old May 27, 2008 | 11:19 AM
nismos14's Avatar
§è~® f®ÈÄk
No, but the bose is i5ucka55
Old May 27, 2008 | 11:45 AM
are you sure? because i am just about to buy one from ebay. and i don't wanna end up with another cd player like before. as you can see my earlier post.
chisam14
Nov 6, 2018 08:56 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
