Where did you guys ground your system in the trunk?
Old Apr 18, 2008 | 12:45 PM
shyheim07's Avatar
Old Apr 19, 2008 | 06:17 PM
shyheim07's Avatar
bump
Old Apr 19, 2008 | 08:45 PM
filtor1's Avatar
You will get 20 different answers. Search. I grounded mine under the car.
Old Apr 19, 2008 | 08:46 PM
filtor1's Avatar
Since this pic I have upgraded to 0gauge. But you get the idea.
Old Apr 19, 2008 | 10:54 PM
DAlastDON's Avatar
Mine is grounded under the back seat on the drivers side between the door and fuel tank.
Old Apr 22, 2008 | 01:58 PM
mx-sed's Avatar
grounded my rigth behind the jack on the right hand side of the trunk.
Old Apr 22, 2008 | 08:36 PM
01GLEMist's Avatar
Me? I like to ground my amps right into my gas tank. I drill right in, make alotta sparks, and then ground 'em right there.
Old Apr 23, 2008 | 08:27 AM
ObsidianIce69's Avatar
Aren't you worried about water getting to that exposed wiring?
Old Apr 23, 2008 | 08:31 AM
OhOhMax's Avatar
That is like saying aren't you worried about your car getting wet if you drive it in the rain?
That is a GROUNDING point, not a power source.
Old Apr 23, 2008 | 09:58 AM
AscendantMax's Avatar
getting that ground wet where chris has it shouldn't be an issue. if anything you can smear some dielectric grease on it to prevent the terminals from oxidating.
i grounded mine in the spare tire well.
Old Apr 23, 2008 | 12:04 PM
filtor1's Avatar
No issues at all with that grounding point. It is well lubed with dielectric grease. That is actually an old pic and before lubing.
Old Apr 23, 2008 | 03:55 PM
OhOhMax...i am aware it is a grounding point, I was talking purely about the wires getting wet and corroding not shorting out...
Thanks for the response Filtor and Ascendant. I like that spot, makes for some good clean wiring.
Old Apr 23, 2008 | 05:16 PM
filtor1's Avatar
No problem. If you are worried about corrosion, either use shrink wrap or dielectric greace and cover any exposed wire.
Old Apr 23, 2008 | 11:46 PM
travmaximas1998's Avatar
filtor where did u go through from inside the trunk?
Old Apr 24, 2008 | 01:09 AM
kpr10is's Avatar
Im going to steal his reply since I know the answer ...
One of the rubber grommets on the left hand side of the trunk floor....one that already had factory wires running through it...kind of near the wheel well. youll see it if you look.
[offtopic]
Im awake at 4 am procrastinating/writing a 10 page paper due at noon. nothing like the last minute.
[/offtopic]
Old Apr 24, 2008 | 10:49 AM
filtor1's Avatar
Yep, like Kevin said, I used a factory gromet. Came out perfect.
Old Apr 24, 2008 | 12:15 PM
ah i see
i dont think i covered that grommet up with my sound deading lol
maxipower
Aug 21, 2015 11:10 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
