Alarm (Ungo brand) Not Working - Replace Main Unit?
Old Apr 22, 2008 | 05:43 PM
triax37's Avatar
Hey everyone -
I have a reasonably simple Ungo alarm that recently stopped receiving signals from the remote. I installed new batteries in the remote, and the signals are being sent out, but the Ungo main unit seems to not receive them. I was wondering if I could just replace the main unit and use the new remotes, instead of having to rewire the whole car.
It seems logical that I could do this, but I thought I would check with everyone first. I have a starter kill on the existing alarm, if that makes any difference.
Thanks!
Old Apr 22, 2008 | 08:08 PM
01GLEMist's Avatar
That is definitely possible, as long as you ensure you get the same model. But, have you checked the antenna for the alarm?
Old Apr 22, 2008 | 11:25 PM
triax37's Avatar
I didn't even know the alarm was hooked into the antenna.
What would you suggest I look for? Thanks!
Old Apr 23, 2008 | 09:55 PM
01GLEMist's Avatar
The alarm should have it's own separate antenna. Off of the brain, it's typically a 3-5 wire harness shrink-wrapped in black. I know on DEI and Compustar units the alarm is usually mounted on a windshield. I'm not very familiar with Ungo units though.
Old Apr 24, 2008 | 04:27 AM
mendon99's Avatar
tastey wheat
If its a cheap unit, it may not have an antenna at all, or sometimes its just a 6" wire. Id take it to an alarm shop as they know what they're doing... My guess is its the remote.
Also, only powered antennas need to be plugged in for the remote to work..
And chances are if he just plugs in a new brain, there is programming that needs to take place before things will work properly.
Old Apr 24, 2008 | 09:50 AM
shyheim07's Avatar
just asking, is there a whay to reset the remote?
You know, so the brain can recognize it? might work
Old Apr 24, 2008 | 10:54 PM
triax37's Avatar
There was a steady decline in reception, to the point where both remotes needed to be right next to the front hood for the alarm to work. That's why I figured it was the brain.
But I'll take it apart Saturday and see if I can find the antenna - maybe there is a short there.
Old Apr 25, 2008 | 04:25 AM
mendon99's Avatar
tastey wheat
this sounds like a battery going bad in the remote.
Old Apr 25, 2008 | 08:31 AM
triax37's Avatar
Agreed. Batteries in both remotes were replaced with new ones though, and that was in the midst of the "steady decline" mentioned above. I feel confident it is NOT the remotes.
Old Apr 25, 2008 | 02:54 PM
chinaonnitrous1's Avatar
Well.....
Ungo should go to the trash.
jerrod99_se-l
Aug 27, 2015 08:27 PM
MikesChevelle
Aug 9, 2015 11:50 AM
MikesChevelle
Aug 6, 2015 11:36 AM
kenc15
Aug 5, 2015 08:29 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
