Audio Install - Recommendations
Old May 18, 2008 | 01:31 AM
Noela's Avatar
Hi,
I retired the following from my old Max, and they've been lying around for the past two years:
Diamond Motorsports M561 Component - 6.5" 2-way
Specifications
6.5" Speakers
1" Tweeters
Crossovers
4.0 Ohms
Power: 120
Image Dynamics IDQ 10" subs: 2 of these
Specifications
Car Speaker Type: Component
Elements: 1-Way
Car Speaker Function: Subwoofer
Nominal Power Handling: 250 Watt RMS (Peak Power Handling: 500 Watt )
Powered: Non-Powered
Frequency Response: 10 Hz - 150 Hz
Sensitivity: 89 dB
Impedance: 4 ohm (Dual Coil)
ESX Quantum 604 (4 channel amp) for the speakers
Specifications
Output Power at 12V:
4 x 60W @ 4 ohms
4 x 90W @ 2 ohms
2 x 180W @ 4 ohms bridged
2 x 75W @ 4 ohms bridged "TRUE MONO"
2 x 120W @ 2 ohms bridged "TRUE MONO"
2 x 180W @ 1 ohm bridged "TRUE MONO"
Dimensions: 10.24" x 9.13" x 2.87" (26cm x 23.2cm 7.3cm)
Built by Zed Audio
ESX Quantum 752 for the subs.
Specifications
2 x 75W @ 4 ohms (12V)
2 x 120W @ 2 ohms (12V)
1 x 240W @ 4 ohms bridge (12V)
1 x 85W @ 4 ohms bridge "TRUE MONO" (12V)
1 x 160W @ 2 ohms bridge "TRUE MONO" (12V)
1 x 230W @ 1 ohms bridge "TRUE MONO" (12V)
1 x 120W @ 4 ohms bridge "TRUE MONO/HI V" (12V)
1 x 210W @ 2 ohms bridge "TRUE MONO/HI V" (12V)
Built by Zed Audio
Clarion Head Unit (ARX7570) and a 6-CD Changer (CDC655z)
I have a 2002 SE without the Bose setup (i think they are still Clarion).
I miss the bass produced by both the ESX amps and the IDQ subs, and was wondering if I could upgrade the audio in my 2002SE with these?
I know these products are old now, but would they work, technically? Would it be worth replacing the front speakers with the Diamond M561s?
Thanks - MN
Old May 18, 2008 | 01:51 AM
chinaonnitrous1's Avatar
Originally Posted by Noela
Hi,
2 Image Dynamics IDQ 10" subs
Clarion Head Unit and a 6-CD Changer (was in trunk)
I know these products are old now, but would they work, technically? Would it be worth replacing the front speakers with th Diamond M561s?
Thanks - MN
I dont see why not...
do it!
Throw the amps in there too!
Old May 19, 2008 | 08:48 AM
nismos14's Avatar
§è~® f®ÈÄk
That setup should sound pretty darn good.
MaxLife17
Jun 27, 2019 01:37 PM
markevans999
Oct 25, 2015 08:27 AM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
