so this headunit only got 2 pre amp outputs (front, and Rear/SUB) so how do i hook it up get a one of those RCA Y plugs and hook the rear to both Rear of the bose amp and sub amp or just use the pre amp outputs to the bose amp and use a line convert with the speaker wires to use with sub woofer amp
thanks
thanks
Quote:
thanks
Your post makes absolutely no sense. If you have a HU that has 4v+ outputs get a metra 70-7551, if not get the schosche adaptor.Originally Posted by imported_D_Roc
so this headunit only got 2 pre amp outputs (front, and Rear/SUB) so how do i hook it up get a one of those RCA Y plugs and hook the rear to both Rear of the bose amp and sub amp or just use the pre amp outputs to the bose amp and use a line convert with the speaker wires to use with sub woofer ampthanks
I meant the headunit only have 2 Preamp out puts (Front, and Rear/subwoofer) and i need the front and the rear for the Bose amp, so where do i hook it up ??
Quote:
You should use the front and rear to the harness, then use a LOC on the outputs to the sub amp.Originally Posted by imported_D_Roc
