Trying To Install These Tweeters in Door Panels
Old May 22, 2008 | 08:55 AM
shyheim07's Avatar
Tryin to figure out how to fit one in each door. Tried it with my other door panels and it's not going to fit casue of the depth. Any guidance would great.
Old May 22, 2008 | 08:58 AM
ElVito1981's Avatar
put them in kick panels instead--that way they'll be down with the mids (where they should be). You don't want your highs closer to your ears than your mids/lows. All frequencies should be as close together as possible.
Old May 22, 2008 | 09:58 AM
shyheim07's Avatar
I tested that out. I didn't like how the sund was in that location. I tured it in the doors and it was supurb to me
Old May 22, 2008 | 10:09 AM
eng92's Avatar
That driver would not have nearly the off-axis dispersion characteristics that a surface mounted dome type would.
If you are going to mount it low, it would need to be directed upward somewhat so that the element is clearly visible.
OP are you sure you want horns in your car? I find them a little harsh personally when you are that close to them.
Old May 22, 2008 | 10:10 AM
chinaonnitrous1's Avatar
whoa,
arent thoes like 4" big?!?!
Some super cheap tweeters?
Old May 22, 2008 | 10:24 AM
BLACKonBLACK98's Avatar
Former Vendor
cut.
Old May 22, 2008 | 12:21 PM
shyheim07's Avatar
yup. super cheap. I'm doing this the way it sounds good to me.
They can be harsh, but i'm only giving them about 50watts each, just to add extra to the tweeters I have in the front.
I still want them in the door, so any suggestions?
Old May 22, 2008 | 12:24 PM
I've heard thoes bullet tweeters,. oh man your gonna be LOUD!
Old May 22, 2008 | 01:43 PM
ElVito1981's Avatar
what are "bullet tweeters"?
Old May 22, 2008 | 05:54 PM
AscendantMax's Avatar
glass them into the a pillars.
Old May 22, 2008 | 07:36 PM
travmaximas1998's Avatar
how deep are they?
Old May 23, 2008 | 12:53 PM
shyheim07's Avatar
not a bad idea at all....
They are rateed 150 watts rms each. I gave them 50watts and I was happy. Anything louder should be considered dangerous.
What about MDF rings? Do you think I can get something for a 4" speaker and fit it in there?
Old May 25, 2008 | 09:54 PM
babyboyws6's Avatar
i have a 5.5 gen and i got a set of tweets where the stock ones where in the front... and put another set in the back door panel with the other mid.. it sounds damn great to me and others who sat in my car in all seats...
i cut a hole and used a dremel sander for a even hole... if you want pics i can upload some for you...
Old May 26, 2008 | 06:47 AM
nismos14's Avatar
§è~® f®ÈÄk
You have tweets already.. and you're adding these?
Old May 26, 2008 | 02:12 PM
djfrestyl's Avatar
Suspension Yoda
This thread is hilarious.
There is no way they're going to fit behind the door panels. If you're looking for HOW to cut your panels, use a hole saw, but it's a waste because it still won't fit.
Find other locations, like the A pillars as previously mentioned. The A pillars are easier/cheaper to replace too.
No matter what you do, the depth of those is going to require glass, and that still doesn't solve the nightmare of dual tweeters.
Old May 26, 2008 | 07:47 PM
shyheim07's Avatar
I'm used to being around club speakers alot and now after year, sound is just not complete to me without em.
I've got MB Quart PCE components with the tweeters in the stock bose locaton. I'm going to see if I can get some kind of MDF rings cut for them to fit, or just glass them in the doors.
Dual tweets, theres noting wrong with that. I have a sound stage that I (this includes me & myself) am use too. Thats why I'm tryin to do this kind of setup. I've stick them there with screws just to test out if thats the proper place to have em.
vingodine
45
May 21, 2016 12:46 PM
doctorpullit
Nov 23, 2015 06:47 PM
umnitza
Sep 1, 2015 01:03 PM
Abdelrhman
Aug 17, 2015 12:16 PM
MikesChevelle
Aug 9, 2015 11:50 AM
