need quick help deciding on which amp...please and thank you
Old May 22, 2008 | 08:39 PM
PandaXpress's Avatar
EDIT
BOUGHT THIS AMP!!!!! SO Pics will go up soon. I hope photobucket loads already.
MB Quart RAA1000 Mono D class amp (wired at parallel)
1000Wrms X 1 channel @ 1 Ohm going to Two 4 Ohm DVC subs which can handle 500wrms
Old May 22, 2008 | 11:44 PM
SuBXeRo's Avatar
wire it in so that u put the amp into 1 ohm, you will get the impendence down low enough, but make sure that the subs can handle 1 ohm. 1000 watts to 2 subs is good.
Old May 23, 2008 | 12:27 AM
ICEMAN76's Avatar
I think what he meant to say is make sure the subs can handle 1000 watts. The subs don't need to handle 1 ohm. 1 ohm is what the amp "will see" if you wire them correctly. Someone please correct me if I'm wrong.
Old May 23, 2008 | 02:56 AM
each sub can do 500 rms...so if I can push 1000 wrms to both subs at 1 0hm I would be good. Lemme know if that sounds good. Should i go to the 2 channel amp that will give 400 wrms per sub at 2 ohms??
Also if anyone could help...What is the displacement of this box? and what is it tuned too? (its two 10's in a single chamber) Will this be tuned down to 32hz? and about 2.5 cf3 displacement with the subs in? Lemem know what you guys think
BOX IS
W 30.5" x H 15.5" x L 16.5"
PORT IS
W 24" x H 14.5" x L 14"
Old May 23, 2008 | 10:03 AM
chinaonnitrous1's Avatar
D class....probably more efficient with the current draw
TallTom
57
Oct 14, 2025 05:16 PM
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
mclasser
22
Nov 12, 2020 01:58 PM
