Grounding a multi-ground terminal?
Old May 29, 2008 | 08:30 AM
chillin014's Avatar
I bought one of these terminal strips at radioshack that look like this.
. My question is...I have to run a ground wire to the terminal in the first place to give it a ground right? What size wire would be appropriate to do this normal 18 GA? I'm going to ground to the engine block.
Old May 29, 2008 | 09:25 AM
nismos14's Avatar
§è~® f®ÈÄk
Why such small gauge wire to ground to the negine block? What are you wiring up? MEVI/00VI?
Yes if you don't put a ground wire on it, where is it going to see a ground? You must run one and I would run 10 gauge.
Old May 29, 2008 | 09:27 AM
chillin014's Avatar
thats why I asked...I wasnt sure if it mattered. I'm wiring up my wideband 02 which has a few grounds to it including a little led. I might ground other things to it as well in the future but I'm afraid to introduce any noise.
the problem with 10 gauge wire is I didnt really see any connectors small enough to fit on those screws that would also wrap around 10 gauge wire.
Old May 29, 2008 | 11:49 AM
chillin014's Avatar
will 14 gauge be alright? isnt the ecu ground only like 18 gauge?
Old May 30, 2008 | 07:13 AM
chillin014's Avatar
Old May 30, 2008 | 07:24 AM
nismos14's Avatar
§è~® f®ÈÄk
14 is fine.
Old May 30, 2008 | 08:25 AM
chillin014's Avatar
Thank you.
pktaske
Sep 4, 2015 08:40 AM
