Installing tweeters correctly
Old Jun 7, 2008 | 02:30 PM
Coolsaber57's Avatar
Hi gang, this thread is actually a real question
I'm preparing to install my Rainbows and looking through the included hardware to see how to install the tweeters in a car that did not have bose, and therefore not having a place to install them. I want to put them in the stock locations as I travel to Baltimore and don't want my car to look like it has something expensive inside (relatively).
Basically, I know I have to cut a hole in the door panel and put the flush-mount cup through, but how do I secure the mount there? There's nothing in the directions about this, only some not-really-useful-info about the angle-mount cup.
How should I proceed?
Old Jun 8, 2008 | 05:54 PM
nismos14's Avatar
§è~® f®ÈÄk
If you cut the hole right, it should be a pressure fit.
Old Jun 8, 2008 | 06:26 PM
That's what I was thinking, but it won't vibrate itself out?
Old Jun 8, 2008 | 06:28 PM
bigleman's Avatar
Advocatus Diaboli
you could do the pressure fit, but the SLCs came with a way to mount the tweeters like that
there are brackets that bolt into the magnet of the tweeter, use those
Old Jun 8, 2008 | 06:32 PM
Are those the black ones with the serated (correct word?) edges?
Old Jun 8, 2008 | 06:41 PM
bigleman's Avatar
Advocatus Diaboli
i have no idea what you're talking about
give me a minute and i'll upload pics of mine
Old Jun 8, 2008 | 06:45 PM
bigleman's Avatar
Advocatus Diaboli
Old Jun 9, 2008 | 07:47 AM
Odd, those aren't what mine look like. You got the Kicks if I'm not mistaken, so maybe the mounting hardware is different.
I'll look tonight and see what I can do with my brackets. There weren't any instructions for some of the hardware, so some of it I had to guess about.
Old Jun 9, 2008 | 08:29 AM
BLACKonBLACK98's Avatar
Former Vendor
it should have come with some kind of u bracket (might not look exactly like those).
another idea for location is in the kick panels, like so (stolen from don):
this is probably how i'll go.
Old Jun 9, 2008 | 08:54 AM
ICEMAN76's Avatar
^'s niiiiice. I wish I had a custom kickpanel like that for my whip.
Old Jun 9, 2008 | 09:35 AM
Interesting, but goes against my "stock-looking" requirement.
I'll check out the brackets tonight and see if I can use them.
Old Jun 9, 2008 | 09:50 AM
Former Vendor
out of sight > stock placement as far as thievery issues.
ideally you should come up with a couple acceptable positions and see which one sounds the best (double sided tape and give it a listen).
Old Jun 10, 2008 | 08:49 PM
NismoVQdet?'s Avatar
you could always put them up in the side like so, but then again it kind of was a lot of work.. would the sound quality be better for my location or from the stock door mounted ones?
Old Jun 13, 2008 | 12:42 PM
CarAudioHelp's Avatar
Are the woofers/mids in the stock door location? Is there enough room to mount the tweeters on the same bracket?
Old Jun 14, 2008 | 11:45 AM
Afronaut's Avatar
Active procrastinator
U can use hot glue to put them in the stock location. U can find it at Wal-Mart, Lowe's, or Home Depot.
Old Jun 27, 2008 | 08:12 PM
sodie14's Avatar
most tweeters have brackets like the ones in bigleman's pix. either way.....putting some hot glue or something on the back is a good way to keep it from vibrating out.
Old Mar 15, 2009 | 06:00 PM
96mAx2fast's Avatar
Out of curiosity, what size are the stock tweeters that are in the A Pillars?
Old Mar 15, 2009 | 06:56 PM
unrealii's Avatar
I suggest to find bose a-pillars at a wrecking yard for your car. Just mount them to the back of the a-pillar (I used a tape and then a layer of adhesive foam to prevent rattling).
Old Mar 17, 2009 | 05:32 AM
djfrestyl's Avatar
Suspension Yoda
Only if he has A-pillars with the grille.
+1, or hot glue as mentioned above.
AaronL
Nov 15, 2020 11:52 AM
MaxLife17
Jun 27, 2019 01:37 PM
wingnut2006
Sep 19, 2015 06:13 AM
DayHeyZeus
Sep 11, 2015 03:17 PM
Johnny9595
Sep 3, 2015 05:18 AM
