Need help hooking up my system please. 300zx thread.
Old Jun 11, 2008 | 03:04 PM
maxfanfromohio's Avatar
Shiver me timbers.
Ok, I have an Infinity Basslink, which I connected the power, audio signal, and ground up to my amp. I have power and sound from the Basslink, but I don't have sound coming out of my Rainbows components which are hooked up to my Diamond amp. I have power from the amp however.
I did not hook up the front speakers through the head unit as I figured they would get their signal from the amp. Is that wrong?
What am I doing wrong here?
Old Jun 11, 2008 | 04:18 PM
nismos14's Avatar
§è~® f®ÈÄk
So you have all the signal wires ran for the amp and everything? no output from the rainbows? Did you adjust the gain on the amp? Is the lpf set?
Old Jun 11, 2008 | 04:41 PM
Shiver me timbers.
Thank you for replying.
All of the wires are run. I don't know what I should have the amp set on as far as the gains on the amp. And I don't know what lpf is. Please help.
Old Jun 11, 2008 | 04:54 PM
ICEMAN76's Avatar
I don't know about the gains. I would probably say halfway. LPF= Low Pass Filter
Old Jun 11, 2008 | 04:57 PM
Shiver me timbers.
What should that be set on?
nismos14's Avatar
§è~® f®ÈÄk
You have to adjust the gains up at least a little, LPF is low pass filter, the crossover on the amp, make sure it is not on.
Old Jun 11, 2008 | 05:10 PM
Shiver me timbers.
Ok, the amp has lpf, hpf, and full. What should it be on?
Old Jun 11, 2008 | 05:27 PM
Shiver me timbers.
If I ground the amp/basslink the basslink kicks on, but the amp goes out. . If I don't have them grounded, the amp is on. Remember, the basslink is running to the same ports the power, remote, and ground are in.
Old Jun 11, 2008 | 08:08 PM
Irish's Avatar
This is a democracy
have it set to full or hpf
Old Jun 11, 2008 | 08:28 PM
nismos14's Avatar
§è~® f®ÈÄk
What?
Old Jun 12, 2008 | 06:06 AM
Shiver me timbers.
What?
I ran the power, remote, and ground from the basslink into the same ports the amp uses, and then to the battery, HU, and ground spot. Does that make sense?
Old Jun 12, 2008 | 06:17 AM
nismos14's Avatar
§è~® f®ÈÄk
Yes, why? Don't do that. Use a distribution block for the power wire. The ground should be straight from each amp to the chassis, not daisy chained. You solved your own problem.
Old Jun 12, 2008 | 06:41 AM
Shiver me timbers.
Thank you. I will try that tonight and report back.
What about for the remote wire? Can that be daisy chained?
Old Jun 12, 2008 | 07:04 AM
nismos14's Avatar
§è~® f®ÈÄk
Remote wire should be okay daisy chained, if not you will need a relay on it with a spdt.
Old Jun 13, 2008 | 12:33 PM
CarAudioHelp's Avatar
Here is a diagram for hooking up a standard Bosch type relay for the remote (if you need it).
http://www.caraudiohelp.com/images/relay_for_remote.gif
The remote from the head unit goes to terminal 86 and terminal 87 goes to the amps (each remote terminal).
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
MichMaxFan
Sep 30, 2015 09:18 AM
Socalstillen
Sep 26, 2015 12:01 PM
