Some help with my system
Old Jun 28, 2008 | 08:04 PM
xorox's Avatar
SO i have a 98 maxima gle and i did full sound system install and i have eclipse avn6620 as my dash and i have 4 6.5" 3way eclipse speakers powered by a phoenix gold 4chan amp and then in the trunk i have a 12" sound stream sup with a soundstream mono amp. But I dont hear my bass as much as i would like to and i dont want to add another sub as it will be more weight. Before when i had the setup without having a 2nd amp to my speakers i could hear the bass really nice and it would shake my car, should i just reduce the speaker amp? or what do i do?
thanks,
chris
Old Jun 29, 2008 | 11:12 AM
travmaximas1998's Avatar
what are ur gains set at?
and the lpf and the hpf?
Old Jul 3, 2008 | 08:18 AM
OMARL956's Avatar
for the four channel you would have to set the amp to hpf so no low notes go through it as for the monoblock check the gain if not your probably not matting the impedenance correctly. how do you have the amps mapped out and ill tell you your problem.
Old Jul 3, 2008 | 08:44 AM
ElVito1981's Avatar
you have two sets of 3-ways? Why? Just need one for the fronts....any more really worsens your sound.
Old Jul 8, 2008 | 09:57 PM
xorox's Avatar
i put the gain up on the mono amp but the 4chan amp i see where it has two options for frequency and some more options that i can also adjust but if i adjust both frequency, that will control how much power i give to the speakers correct? so lower the frequence the lower the speaker sound is correct?
Old Jul 8, 2008 | 10:41 PM
the frequency has nothin to do with the power the speakers are seeing.
the filters just keep unwanted frequencies from getting to speakers that dont handle that range of frequency
hpf for ur tweeters, mids
lpf for ur subwoofer
Old Jul 11, 2008 | 10:58 PM
Kreapin's Avatar
What model # is the bass amp? What model is the sub? How many ohms is the sub? What is the model # of the 4 ch amp? All of this is needed to understand what your equipment is and what is best settings. 1 good 12" sub with a good quality amp is more than enough most of the time, but you just need to set it up right - that goes for just about anything. I will do my best to help (as many others here will also) but need more info.
Old Jul 15, 2008 | 09:28 PM
96gxeblaxima's Avatar
id say you need to tune both amps to see where they blend together to your liking. mess with the gains on both amps but as other members posted make sure your using the hpf on your interiors and the lpf for your sub. pics could also help to see where your settings are at and another member could possiby help you out that way.
Miket2006
Mar 1, 2021 03:55 AM
MichMaxFan
Sep 30, 2015 09:18 AM
Socalstillen
Sep 26, 2015 12:01 PM
RWCreative
Sep 21, 2015 11:01 AM
