????? > 15" Kicker L7
Old Aug 25, 2008 | 10:24 AM
Majestic's Avatar
Yahhhhhhh
Fill in the blank. Right now I have a 15" Kicker L7 in a small ported box. I am looking to get something that's just as loud but punches harder. I also want it to hit lows just as good as the L7. I was looking at the MTX Jackhammers. The 400rms version not the cheaper ones. I think I prefer a dual subs (ported) as opposed to one sub. I do not want to spend over $400 since that's the cost of the jackhammers.
Any recommendations? (Keep price range in mind)
Old Aug 25, 2008 | 10:53 AM
AscendantMax's Avatar
15" Fi Audio Q or BL
https://ssl.perfora.net/www.ficaraud...iew.shopscript
Old Aug 25, 2008 | 11:02 AM
Majestic's Avatar
Yahhhhhhh
Originally Posted by AscendantMax
Interesting. I'm thinking dual 12s though.
Old Aug 25, 2008 | 11:57 AM
nismos14's Avatar
§è~® f®ÈÄk
If you want the lows and louder, get a 15.
Old Aug 25, 2008 | 12:43 PM
meccanoble's Avatar
Sports Button FTW
why dual sub if you can get same power from 1? Subs are already heavy to begin with...
Old Aug 25, 2008 | 12:45 PM
Majestic's Avatar
Yahhhhhhh
Well that's just it. I'm really asking more than anything. I've had several subs over the past few years but never two good 12s so I figured something like 2 12" type-x's or jackhammers would be louder than the 15" L7. Is that true?
Old Aug 25, 2008 | 01:02 PM
meccanoble's Avatar
Sports Button FTW
not even sure...although a 15" with the right amp should definitely do you justice...
I got a 12L7 with a 1000 watt rms alpine amp and I get more bass than I'll ever need with amp moderately turned up. (car can barely take it) Not the cleanest bass I've heard/felt but definitely enough...maybe you are looking into more SQ and not so much SPL (kickers notorious for strong SPL, weak SQ)...or maybe you should check your amp and think of upgrading that? If you are looking for straight bass, I think of the 15" L7 as one of the strongest in that field....
Old Aug 25, 2008 | 01:41 PM
filtor1's Avatar
I will second these if you want to stay with a single 15".
If you want to go with a pair of 12"s, Even a pair of SSD's has the ability to obtain your goals.
Old Aug 25, 2008 | 04:56 PM
getting dual 12s is fine and will get damn loud. but i just like the low end of a 15.
i say get a 15" Q or BL, feed it ~1kw, in a nice ported box and it'll definately make your ears feel funny.
Old Aug 28, 2008 | 12:46 PM
stronium_95se's Avatar
re xxx
Old Aug 28, 2008 | 01:31 PM
filtor1's Avatar
Originally Posted by stronium_95se
re xxx
If he could find 05' or prior model, I would agree with you. It will be a PITA to find 2 12"s in similar condition though. Not a huge fan of the current design. It has a few flaws.
Old Aug 28, 2008 | 03:59 PM
^ not to mention it weighs a ton.
Old Aug 28, 2008 | 04:53 PM
filtor1's Avatar
Good point. One of many.
Old Aug 29, 2008 | 06:56 AM
Torgus's Avatar
there are plenty of subs which will get louder than an L7.
XXX <--so hot
DDs
BTLs
etc.
the enclosure is extremely important as well.
and asking for "something just as loud but punches harder" makes 0 sense.
Old Aug 29, 2008 | 07:37 AM
JEXTEL's Avatar
if you cant afford a better sub why not build a better box..i know the L7's like bigger boxes and tuned it to about 32hz and see what that does???
Old Aug 29, 2008 | 07:50 AM
Majestic's Avatar
Yahhhhhhh
Best advice so far I think. That's a great idea. Just need all the facts since my last attempt at making a box failed miserably. I know I need cut MDF, some type of sealant glue, carpeting, a drill, screws, what else?
Old Aug 29, 2008 | 07:56 AM
Just use some good wood glue during the assembly. if you're going to use screws, always predrill first to reduce panel splitting. also, don't use an excessive amount of screws since it will start to weaken the joints. i personally use a nail gun. it's so much faster and cleaner looking.
Old Aug 29, 2008 | 08:09 AM
^^awesome box builder ,
Old Aug 29, 2008 | 08:24 AM
^ haha hows that sub treatin ya? it got pretty loud.
Old Aug 29, 2008 | 08:47 AM
Majestic's Avatar
Yahhhhhhh
man that box looks great...where do you get the carpeting.
Old Aug 29, 2008 | 04:18 PM
i got it from a local warehouse that sells a bunch of upholstery stuff.
Old Aug 30, 2008 | 06:41 AM
Torgus's Avatar
what does: "something just as loud but punches harder" mean???
Old Aug 30, 2008 | 08:46 AM
^ more impact?
definately possible with a good sub.
Old Aug 30, 2008 | 12:04 PM
haha still loving the surprised faces when I pop trunk and show people its only 1 sub.
Old Aug 30, 2008 | 10:21 PM
big port area ftw
xxxmarine79
Aug 3, 2001 05:12 PM
JacksMax
Mar 2, 2001 02:31 PM
