A pair of 12s IB in a G37?
Old Sep 13, 2008 | 07:36 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Yes it can be done.
First template..
Then assembled ..
BUT will it fit ??
Old Sep 13, 2008 | 07:38 PM
Pearl96Max's Avatar
Score !
Old Sep 13, 2008 | 07:41 PM
Kevlo911's Avatar
Kevlo for President
Too loud
Old Sep 13, 2008 | 07:57 PM
Pearl96Max's Avatar
Not at all, theyre just right.
Old Sep 13, 2008 | 09:34 PM
ICEMAN76's Avatar
What kind of subs are those?
Old Sep 13, 2008 | 09:37 PM
Pearl96Max's Avatar
Dynaudio MW190
Old Sep 13, 2008 | 10:20 PM
ICEMAN76's Avatar
They look Shweet!!
Old Sep 14, 2008 | 08:54 AM
Pearl96Max's Avatar
Indeed
Old Sep 14, 2008 | 11:25 AM
ICEMAN76's Avatar
I wish I had a money tree!!
Old Sep 14, 2008 | 11:45 AM
Pearl96Max's Avatar
Me too.
Old Sep 14, 2008 | 05:04 PM
ICEMAN76's Avatar
How
How did you seal off the the cabin from the "trunk"? Was the baffle enough to seal the trunk and separate the waves?
Old Sep 14, 2008 | 05:14 PM
meccanoble's Avatar
Sports Button FTW
wow, looking real good. I wonder how loud they get....
Old Sep 14, 2008 | 05:22 PM
Pearl96Max's Avatar
The baffle was enough.
Old Sep 14, 2008 | 06:07 PM
ICEMAN76's Avatar
true great work as always!!!!
Old Sep 14, 2008 | 08:22 PM
filtor1's Avatar
looks great Don! I am not a huge fan of those hurricane nuts though. They sure do look nice when they are done.
Old Sep 14, 2008 | 08:25 PM
Pearl96Max's Avatar
Hurricane nuts? WTF are you talking about? You mean like T-nuts?
Old Sep 14, 2008 | 08:26 PM
filtor1's Avatar
One more ramdon question, are the G37 rear speakers in the rear deck or in the rear passenger arm rests like they were on older coupes? The last IB G I was a part of we had to seal off the rear deck, there were speaker holes but the speakers were actually in the rear passenger arm rest. Just Curious.
Old Sep 14, 2008 | 08:31 PM
filtor1's Avatar
Yep! Same thing.
Old Sep 14, 2008 | 08:32 PM
Pearl96Max's Avatar
Side panels.
Old Sep 14, 2008 | 08:33 PM
Pearl96Max's Avatar
Yep! Same thing.
Then yes quite teh garbage. I never use em. Dont even have any laying around, ever.
Old Sep 14, 2008 | 08:36 PM
filtor1's Avatar
I need a fricken router. I will take this to the "other" thread as to keep this one tidy.
Old Sep 14, 2008 | 08:38 PM
Pearl96Max's Avatar
I have three.
Old Sep 14, 2008 | 08:39 PM
Pearl96Max's Avatar
Why did you bring up T-nuts anyway?
Old Sep 14, 2008 | 09:20 PM
filtor1's Avatar
I have three.
This and 16hrs seperates this fact from being helpful.
filtor1's Avatar
Isn't that what you used to secure the driver to the baffle?
Old Sep 14, 2008 | 09:50 PM
Pearl96Max's Avatar
Hell no, I just dont trust em. I used knife inserts. Glue, then thread.
Old Sep 15, 2008 | 05:33 AM
eng92's Avatar
I use both in my woodworking proijects.
A T-nut, when installed from the backside, is mechanically stronger than a knifed insert, installed from the front, of the same thread size. For a T-nut connection to fail, the whole section of base material has to pull out. With the threaded inserts, only the net section of the threads needs to pull out.
When you want a smooth backsurface and/or only have access to the panel from the front, then the inserts are the way to go. I am using them to attach my amp board to the existing plywood panel (behind the rear seats) in my IB setup.
For the strongest bolted connection and when you don't care what the backsurface looks like, I think T-nuts are the way to go. Also where I live, they are alot easier to find and cheaper. I usually have to order my inserts online.
Old Sep 15, 2008 | 06:37 AM
Pearl96Max's Avatar
My primary gripe is when a tooth or teeth break. Cheap nuts perhaps? I have had a few instances with a driver stuck inside an enclosure due to broken teether and the nut just spins when trying to remove the bolt.
Also in most cases I need the back side to either be clean or at least appear so. Flushing a T nut isnt that difficult, but still more work than I want to apply.
Old Sep 15, 2008 | 07:01 AM
eng92's Avatar
Wow, I have never seen a tooth break, but I have seen regular particle board crumble which produces the same effect.
Old Sep 15, 2008 | 07:06 AM
nismos14's Avatar
§è~® f®ÈÄk
Looks great.
Old Sep 15, 2008 | 09:45 AM
filtor1's Avatar
I usually had trouble with the box coming apart and me having to scrap the project and build a new baffle. This only happened once though. I was irritated enough to not use the product again.
Old Sep 15, 2008 | 10:13 AM
Deckdout2's Avatar
Play with my balls
Nice setup!
Old Sep 15, 2008 | 11:48 AM
meccanoble's Avatar
Sports Button FTW
just curious what type of amp is pushing those beauties and how does the owner feel so far about the sound? Setup looks so clean, just want to do it to show off...
Old Sep 15, 2008 | 11:53 AM
Pearl96Max's Avatar
A pair of Zapco 6 channels to run 4 way active.
He absolutely friggen loves it ! He wanted me to toss his JL sub in the trash.
Old Sep 15, 2008 | 05:00 PM
filtor1's Avatar
LOL! IB FTW. One day I may have a system worthy of this in a car I haven't tried to be loud in. One day I tell you, one day.
Old Sep 16, 2008 | 06:07 PM
mendon99's Avatar
tastey wheat
nicely done. When i read the thread title i was thinking off the rear deck..
Id like to do one of these installs at my shop someday.
Old Sep 16, 2008 | 07:56 PM
Pearl96Max's Avatar
It was fairly easy as most are, but it would have been ALOT simpler had I had the car here the whole time.
IF you get a G37, lemme know I think I saved a template.
Old Sep 17, 2008 | 04:51 AM
mendon99's Avatar
tastey wheat
will do. i dont suppose you have it on a computer program though, right? lol
Old Sep 17, 2008 | 05:51 AM
swowlinc's Avatar
1993 SE
The MW190 is a large powerful driver intended for woofer and subwoofer applications in high quality car audio systems.
The driver is applicable in a wide variety of boxes, closed as well as vented.
The unusually large voice coil ensures not only high power handling, but deep, tight, and detailed bass reproduction without any compression. Frequency response: 25Hz - 800Hz; 92 dB sens. 200 watts continuous.
throw the JL's away?? wtf?
Old Sep 17, 2008 | 06:19 AM
Pearl96Max's Avatar
No sir.
