AMP Question?
Old Oct 19, 2008 | 03:28 PM
Professor's Avatar
AMP Question?
I have a Fosgate P500.2, Is there any relays in the amp? i really dont want to pull the cover because its pretty new, I notice when its cold and i turn it on i hear a "servo sound" like the steering on a RC car, after while it goes away, the amp works fine and is wired with 2 gauge wire.Others have said it could be a relay under the dash on the pass side, but all i could find is the blower motor one, i hear it even with the motor off, The amp is under the Pass seat.
Old Oct 19, 2008 | 03:38 PM
nismos14's Avatar
§è~® f®ÈÄk
I doubt there is one inside the amp.
Old Oct 19, 2008 | 04:42 PM
07Maximan's Avatar
I agree,Ive never heard of anything like that before.
Old Oct 19, 2008 | 08:24 PM
Andrew's Avatar
Never heard of that before either. Are you sure its not your CD player? It sorta makes the same sound.
Old Oct 20, 2008 | 07:49 AM
Professor's Avatar
Nah its coming from the pass side somewhere, only does it when i turn the head unit on, even with no cd, source on fm radio or aux i still hear it.
Old Oct 25, 2008 | 03:44 PM
speedbee29's Avatar
I worked at Rockford for a little bit as a repair tech, and if its not anything with your car (motors, relays, etc.) It sounds as if its the amps transformer buzzing. Quick fix that works requires opening up the amp, if its new enough, send it in for warrantee repair, and they will most likely replace the transformer all together.
I need a wire diagram for a 01 max stereo system.
Old Nov 30, 2008 | 03:03 PM
Professor's Avatar
Iam still having this issue, its definitly comming from somewhere behind the glove box, Only when the headunit is on, its squealing and it does it with turn signals, heater, rear defrost, ive noticed once it finally kicks in the lights dim like a surge like something is engaging, then they come back to normal lvl.
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Socalstillen
Sep 26, 2015 12:01 PM
