installing a remote starter and have a couple of questions please help
Old Nov 26, 2008 | 04:23 PM
imported_D_Roc's Avatar
car is a 2001 maxima
1. for the door locks does this car have a positive or negative trigger
2. there is a wire is says "Factory security rearm signal output" what is this
for the description is: This out put is programmable, if programmed it can rearm a factory installed security system.
and also something about grounding it with a switch, so is this just a ground or what...
3. Another wire called "dual pulse door unlock output" i got a my cars wiring diagram and there's only lock and unlock noting about the pulse thing
i have installed systems before but it was on a 93 mercedes and a 95 ford wasn't this complicated
also the starter is a BUlldog DELUX 200, yea i know it sux but gets the work done and got it for free
thanks
D
Old Nov 26, 2008 | 04:28 PM
mendon99's Avatar
tastey wheat
1. negative
2. ignore this wire, car arms and disarms with lock and unlock
3. Yes you need to turn on double pulse unlock.
Id suggest a better unit, that bulldog will fail in less than a month. and the range is worse than stock.
good luck!
Old Nov 26, 2008 | 04:30 PM
so for #2 just cut off that wire and 3. where do i hook that wire to?
thanks
D
Old Nov 26, 2008 | 04:33 PM
mendon99's Avatar
tastey wheat
its a programming feature. Read the install manual, when you go to program the starter there should be an option for double pulse unlock, that needs to be on.
Old Nov 26, 2008 | 06:46 PM
and one more what are these arrows mean, i know that the dot mean connect them and the half circle thing is skip it
Old Nov 26, 2008 | 07:56 PM
kpr10is's Avatar
Pretty sure the arrows would mean the factory wire continues in that direction, meaning you are simply tapping into that wire, not cutting anything.
Old Nov 26, 2008 | 08:01 PM
thanks
Old Nov 26, 2008 | 09:00 PM
also this way all i ahve to do it hook 2 wires to the pin #23 Power lock in the SECU and pin #35 Power Unlock In the SECU rite? i don't have to wire each wire to each switch
ah2002
Mar 9, 2016 01:42 PM
FlaMark
Jan 8, 2016 07:21 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Samedi
Aug 13, 2015 04:05 PM
maximaham
Aug 7, 2015 01:11 PM
