Stero Gurus Needed: Bad Wiring Harness?
Stereo Gurus Needed: Bad Wiring Harness?
I have a 97 SE with Bose and i had an aftermarket pioneer deck (DEH 3900MP) installed. At first the deck was working fine but it started acting up. I started getting scratchy and popping noises and sometimes cut outs from my passenger side front and rear speakers. Some days it would work fine and all of a sudden I hit a bump and one of theses speakers starts making noise or cuts out. The scratchyness and popping seemed to be directly related to bumps I went over and even if I tapped on the head unit face this would result in the same problem. I figured that i must have a loose connection.
Last weekend i took the dash apart and checked the connections. The wiring harness or adapter thats connected to my pioneer deck into the stock power and speaker harness looked fine but every time I moved the harnesses together or tapped or touched the connection the stereo would either cut out, loose power, or sound scratchy or poppy. I kinda got fed up and put everything back together. Stereo worked fine for half a day but now I have power to the deck and absolutely no sound. I think its a bad harness between my deck and car. Is there something i am missing? Could I possibly also have a bad harness from the car. What can I do to check? Thanks!
The Frye
Sep 2, 2021 11:03 AM
