Noob questions for installing a system
Old Dec 19, 2008 | 02:27 PM
Andrew's Avatar
Hey all,
I'm thinking about putting my amp under my seat. If I take the seat out and mount the amp to the car, will I be drilling through the floorboards? How would I mount the amp to the floor under the car seat? Sorry but this is my first time putting in a system in a car. Thanks!
andy
Old Dec 19, 2008 | 03:30 PM
filtor1's Avatar
Unless you use some uber adhesive velcro, you will need to drill into the car. I have seen it done both ways w/o issue. Just make sure your amp can actually fit under the seat before permenantly mounting it.
Old Dec 19, 2008 | 07:28 PM
Andrew's Avatar
hmm ok, thanks. I'll see what I can do now. thanks
Old Dec 19, 2008 | 08:27 PM
Pearl96Max's Avatar
I tend to get a bit irritable
No, not necessarily. Easiest method without drilling through the floorboard and being 100% secure would be to lift the carpet, lay a board under, lay the carpet back down and mount to the board. For added measure you can epoxy/caulk it to the floorboard. Caulk, like strip caulk can be removable and pliable.
Old Dec 19, 2008 | 08:28 PM
Pearl96Max's Avatar
Hmmm ...
I never had a mentor. I have always been into it. Since 5th or 6th grade. I used to have my mom take me to car shows.
I figure after THAT many years, you would have been more creative.
Old Dec 19, 2008 | 09:20 PM
filtor1's Avatar
Originally Posted by Pearl96Max
Hmmm ...
LOL. Quoted from the other forum. Nice. There was no better answer.
Old Dec 19, 2008 | 09:21 PM
filtor1's Avatar
I had never thought of that before. Might add too much hieght though. Just make sure it will fit.
Old Dec 19, 2008 | 09:27 PM
BLACKonBLACK98's Avatar
Former Vendor
theoretically you could even do it with sheet metal and pop rivets to keep the thickness down. i love me some rivets.
Old Dec 19, 2008 | 09:38 PM
Pearl96Max's Avatar
Not if removing/flattening the jute below the carpet. Same height in the end.
Old Dec 19, 2008 | 09:39 PM
Pearl96Max's Avatar
That could flex more and resonate with vibration. Also PITA to align holes that you cant see with a rivet gun.
Old Dec 19, 2008 | 09:41 PM
Former Vendor
deadened sheet metal? lol... i dunno... just brainstorming but the juste removal sounds good to me.
Old Dec 19, 2008 | 09:45 PM
NismoVQdet?'s Avatar
has anyone thought about the heat and it wont have anywhere to escape.. i don't know about you but my amp has fans on it to keep it cool and if it can't breath then it shuts off to keep it from over heating.. just something to think about..
Old Dec 19, 2008 | 09:51 PM
Pearl96Max's Avatar
Wrap it in carpet too ! Now even more stuff to try to rivet through !
Pearl96Max's Avatar
It has been done for decades with no issues, no point in starting to worry now.
Old Dec 20, 2008 | 06:20 AM
Andrew's Avatar
True, I still see amps being mounted under the seats. I'm just too lazy to run wires to the back on the trunk and back to the components.
Plus I have an old Alpine V12 amp. I don't think they have fans in them.
Old Dec 20, 2008 | 10:56 AM
filtor1's Avatar
Add a low voltage quiet fan under the seat. Have it turn on with the remote wire with the amp. Just a thought. They are pretty cheap and from the ones I have seen are super quiet.
Old Dec 22, 2008 | 03:20 PM
Andrew's Avatar
Could you send me a link to what you are talking about? I'm thinking computer fan here! LOL
Old Dec 23, 2008 | 11:13 AM
djfrestyl's Avatar
Suspension Yoda
^^^ that would work.
Old Dec 31, 2008 | 04:28 PM
Andrew's Avatar
ok quick question.
I have a set of the rainbow components that I purchased here from Don a while ago. Do I need to add spacers to the front doors? and if so, what size/thickness do I need? thanks!
Old Dec 31, 2008 | 11:25 PM
djfrestyl's Avatar
Suspension Yoda
3/4" would be dead on.
Old Jan 1, 2009 | 12:04 AM
Andrew's Avatar
Thanks..i guess these are it?
http://cgi.ebay.com/mdf-6-1-2-subwoo...lenotsupported
Old Jan 1, 2009 | 10:10 AM
djfrestyl's Avatar
Suspension Yoda
Yea, those would do.
Old Jan 12, 2009 | 05:01 PM
Andrew's Avatar
ok here's another question. Usually I take the integration adapter and solder the wires to the radio plug. This makes a better connection instead of twisting the wires and capping them. Its just me being paranoid. Anyway, if I'm hooking up an amp, should I still solder the wires that goto the front speakers? I've never really hooked up an amp to a car stereo before but it shouldn't be that hard.
Old Jan 12, 2009 | 05:06 PM
djfrestyl's Avatar
Suspension Yoda
No, if you're hooking up an amp, then the speaker leads are going to be coming from the amp, not the HU. It would be a waste of time.
And, depending where/how you leave your OEM speaker leads, if you do solder them to the HU, you could potentially short out your HU.
Old Jan 12, 2009 | 05:07 PM
Andrew's Avatar
btw, I received these rings today but the speaker doesn't 'fall in'. Is it supposed to be flush when I put the speaker in?
Old Jan 12, 2009 | 05:46 PM
djfrestyl's Avatar
Suspension Yoda
Yes, you may have to shave those a bit.
Old Jan 12, 2009 | 05:54 PM
Andrew's Avatar
Thanks man
Also, I'll try to get those rings shaved a bit so they will be flush.
Old Jan 12, 2009 | 05:58 PM
djfrestyl's Avatar
Suspension Yoda
No problem, good luck.
JRod28
Dec 29, 2023 09:56 PM
rbuswell
Nov 17, 2016 04:54 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Hawkeye61
Aug 12, 2015 06:45 PM
Team STILLEN
Aug 10, 2015 04:29 PM
