Carpet padding (ATTN: Anton)
Old Nov 14, 2001 | 05:37 PM
Mike H.'s Avatar
I checked out Home Depot this afternoon and found carpet padding gallore. They had them in different colors and weight. I would assume that the heavier it is, the better the sound dampening? What weight did you use? I only saw 3 and 6 lbs. Also, they were all foam with some string wiring in it. But there was another one that looked like fused fiber. Is that one better? What type of carpet padding did you use? Thanks.
Regards,
Mike H.
Old Nov 15, 2001 | 07:23 AM
Whitemax's Avatar
Disco Biscuit
I used the top of the line carpet padding from Home Depot.
Old Nov 16, 2001 | 03:50 PM
SWEETSOUND2001's Avatar
well...assuming you already looked at my homepage and read everythinng you'd know that I bought my carpet padding from www.jcwhitney.com. I would use the thickest, heaviest stuff that you can possibly fit.
Anton
Old Nov 17, 2001 | 10:37 AM
jmax
I think the "fused fiber", I think they call it yute, jute, damn, i can't remember. But I think that is what is pictured on sweetsounds' page.
Old Nov 17, 2001 | 10:45 AM
Old Nov 17, 2001 | 01:28 PM
jmax
I stand corrected.
Old Nov 17, 2001 | 05:29 PM
ZIPPIN's Avatar
Mauja He Mauja
Anton
**** retention ( | )
Old Nov 17, 2001 | 11:45 PM
Ndo125's Avatar
Where do you guys installed this??
doors?
and how??
Old Nov 18, 2001 | 08:27 AM
jmax
Install between the vinyl covered door panel and teh steel door. Use as a damper, gasket, and isolation pad. Also install under carpeting and over headliner.
Old Nov 18, 2001 | 09:58 AM
Ndo125's Avatar
Sounds hard....especially under carpeting and over headline...
any pictures on doing it?
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
Derrick2k2SE
Nov 19, 2015 10:14 PM
fastcarny
Oct 12, 2015 07:06 AM
sliptap
Sep 30, 2015 05:57 AM
