Monitor Your Audio System with these Gauges!
I'm thinking of buying the Power Acoustik Meter-4 System. It measures Amp Temp., Voltage, and has two VU (Volume Unit) Meters. I just want to know has anyone installed a system like this in their maxima? I just want to get some info on the difficulty of the install process before I pull the trigger and buy the system. THANKS!
only issue i'm seeing is the cable. seems like it's only for amplifiers with the phone jack connector, and even then it would have to output the right signal. the middle 2 gauges are worthless anyway and voltage/amp temp gauges are easily available. add to that the brand and i'd pass. the only thing really cool about it is the din sized housing.
looks useless to me. but if you really car about it all i assume the install would be very easy, other then the hassle of running 4 more wires all over your car. i'd put in a single din EQ before that...
