0 Guage Terminals...Crimping, etc....
Old Jan 20, 2009 | 02:21 PM
shyheim07's Avatar
So I need to start doing 0 guage wiring. Question is on how folk do it on the org. I need 3 leades of 0 guage from positive and negative on the battery. Question is what terminals can you guys recomend or how can I go about adding some brass terminals to em?
(Last time I just used a hammer, but might be a better way or 2.
Old Jan 20, 2009 | 02:31 PM
filtor1's Avatar
I use standard ring terminals for 0gauge and hammer away. I have used a teminal crimper but found the hammer to be just as effective.
Old Jan 20, 2009 | 02:55 PM
AscendantMax's Avatar
yep, what chris said. you can just put the terminal on the ground and beat the crap out of it with a hammer so it 'crimps'. OR you can take a butane torch, and heat up the wire and melt some solder onto it locking the terminal in place.
Old Jan 20, 2009 | 02:58 PM
travmaximas1998's Avatar
i used the terminal that are sort of open and used some big channel locks to crimp it! worked very well
but if i could i would use the solder method with the crimp
Old Jan 20, 2009 | 03:01 PM
filtor1's Avatar
I have never used both methods, but overkill never hurt anyone.
Old Jan 20, 2009 | 03:58 PM
Andrew's Avatar
Use the hammer. Forget the crimper. I just crimped 4 guage wire with ends and let me tell ya, I think I busted a hernia from doing do. Wack it with a hammer. Easier...
Old Jan 20, 2009 | 08:13 PM
MadMaxSE-L's Avatar
Doggah Bite...
You can also use a vice if you have one, saves from accidentally hitting and breaking the insulation if you are a bad shot with the hammer.
Having said that, I used that connections from Street Wires that you pull the wire through and bend it over then end, kind of like a mushroom. Then you screw the end down that has the actual ring on it to lock it. Kind of expensive though if that matters...
-Matt
Old Jan 20, 2009 | 08:21 PM
djfrestyl's Avatar
Suspension Yoda
Beat the crap out of it, easiest.
If you want to be slightly more precise, get a pair of pliers and bend the slit in the crimping ring so one side slips under the other. Then squeeze, THEN beat the crap out of it.
Old Jan 20, 2009 | 08:48 PM
thats what i did without the hammering, just had a buddy of mine squeeze the **** out of the channel locks
Old Jan 20, 2009 | 09:12 PM
djfrestyl's Avatar
Suspension Yoda
Pfff. Wimps.
I do it bare handeded.
Old Jan 20, 2009 | 11:45 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Umm, I use a crimper. Whats with all this 'beat the crap out of it' ? Me thinks you guys have some built up anger and aggression you need to outlet somewhere else.
Old Jan 21, 2009 | 12:29 AM
i like to solder mine...maybe i just like playing with fire...
Old Jan 21, 2009 | 07:28 AM
Coolsaber57's Avatar
Lol...maybe...
I hammered mine as well...I didn't have/feel like looking for a huge wire crimper. That and I didn't feel like paying for a tool I'd use 2-3 times in my life
Old Jan 21, 2009 | 07:59 AM
eng92's Avatar
I picked this set up a few years ago for $25 from a local surplus store
They are adjustable for lugs/terminals from 8GA right up to 4/0
Old Jan 21, 2009 | 09:42 AM
shyheim07's Avatar
Thats the tool i used before. My uncle owned it, but when he lest to texas, so did that thing
Old Jan 21, 2009 | 09:47 AM
Matt93SE's Avatar
STFU n00b!
They don't care how ugly it looks.
Crimp & solder & shrink wrap FTW.
Old Jan 21, 2009 | 10:28 AM
BLACKonBLACK98's Avatar
Former Vendor
what's your weapon of choice don? i was lookin at this klein crimper:
good buy or something better for the/less money?
Old Jan 21, 2009 | 10:53 AM
Pearl96Max's Avatar
Its a good buy, but I still use the standard Klein crimper.
Old Jan 21, 2009 | 02:56 PM
Former Vendor
this one? i used this one for 4 gauge a couple weeks ago and it didn't come out super clean. kinda had to pre-bend it and even then it was off center because the jaws weren't quite big enough.
Old Jan 21, 2009 | 03:45 PM
djfrestyl's Avatar
Suspension Yoda
^^ I use that one too. It works to bend the ring inwards, but I still use a hammer to make it tight.
Old Jan 21, 2009 | 03:47 PM
Former Vendor
yeah... i got it to clamp down plenty tight enough and with the connector boot it didn't look bad... but i knew what was under there.
Old Jan 21, 2009 | 09:17 PM
Pearl96Max's Avatar
That is the one I use.
Old Jan 22, 2009 | 07:20 PM
captain jack's Avatar
First post of all places. There is also a small anvil type of thing that I have. You put the cable and connector in there and hit it with a hammer. Not sure where I got it but that is what it's designed for. Honestly though I'm never happy with how tight it makes the connection so I end up soldering it. And if you have to do one while one end is attached in the car you can't really use it. I've made my own grounding kits using the solder and heat shrink method and that worked best for me.
Old Jan 22, 2009 | 10:04 PM
bumping96's Avatar
I use a hydraulic crimper that I barrow from my work it works great. It comes with inserts for different size terminals.The only bad thing is it takes two people to use it because have to pump the handle until valve blows off so someone else has to hold the terminal and the wire.
Old Apr 17, 2009 | 09:10 AM
gallilaw's Avatar
I use a very large Vice-Grip plier. It fits every size wire and terminal, because you can adjust the jaw opening. It provides great crimping leverage. For a large ring I start with the jaws fairly wide, crimp the ring a bit, then adjust the jaws narrower. For large rings I might adjust the jaws three or four times. The result is very strong but also probably a lot neater than banging the rings with a hammer.
Old Apr 17, 2009 | 11:09 AM
Deckdout2's Avatar
Play with my balls
I use this little number to crimp all my installs. Mainly for headunits.
Old Apr 17, 2009 | 11:55 AM
hardincah's Avatar
Pfff. Wimps.
Cotozic
Jun 28, 2017 08:01 PM
rnb754
Sep 14, 2015 11:39 PM
95Maxi
Aug 25, 2015 08:01 PM
