Sound insulation
Old Nov 15, 2001 | 04:04 PM
Kevin Wong's Avatar
Sound insulation
I was wondering if styrofoam would work as a good sound insulator or is it just a thermal insulator? I started to sound dampen the car with Raammat, bedliner, expanding foam, and the like. I was working on the doors when I noticed it was just a hollow cavity. So far the rear door is Raammatted and sprayed with bedliner. I was thinking of filling in the hollow frame with packing peanuts in a plastic bag. Is this just another lame idea?
Old Nov 15, 2001 | 07:45 PM
Whitemax's Avatar
Disco Biscuit
Yes foam does absorb sound better than raammat and the like. Those products are good at killing vibrations and thats pretty much it. Styrofoam I guess would work, but I havent used it. A couple of us have used carpet padding from Lowes or Home Depot and it does make a nice difference.
Old Nov 15, 2001 | 09:02 PM
jmax
Kevin,
I have done what you mention using large zip-locks and polyfill or owens corning myraflex. But not in the doors because of the window that needs free space within to move. My rear fenders are stuffed with myraflex.
Old Nov 15, 2001 | 09:25 PM
Kevin Wong's Avatar
great
thanks guys for your input. I'll get to work on this soon.
Old Nov 17, 2001 | 11:28 PM
Ndo125's Avatar
I want more info
What kind of Styrofoam you use?? where to get??
So, do you open your door panel and stuffed it with styrofoam and spray it with bedliner??
They sell some kind of spray chemical at autozone and claimed to reduce the road noise, is that really works?
I really want to reduce my 95 GLE's road noise.............so please help..............
Old Nov 18, 2001 | 08:33 AM
jmax
If you read my post above you will see I didn't use styrofoam. But if you want the equivalent in the doors continue reading. Go to home depot. Get one 4X8 sheet of foam board insulation. Cut a piece to fit below the steel beam in the door and one to fit below. Now cut horizontal strips half the thickness of the foam board. These strips will allow it to bend. Spray the sheet metal and the foam with spray adhesive and attach. Personally I would use at least one layer of a quality damping material before applying the foam.
Old Nov 18, 2001 | 10:02 AM
Ndo125's Avatar
Will it interfere w/ power window?
and what kind of quality damping material that you suggested?
Thanks a lot, I'll try it later.....
Old Nov 19, 2001 | 08:15 AM
jmax
If you adhere to the outer door skin it will be at least a couple inches from the window path. The steal beam is at least 1 inch diameter.
Common damping materials:
Cascade audio mass loaded vinyl
Dynamat
Raammat
Lowes carries a roof flashing material with viscoelastic rubber adhesive, by far the cheapest
Driveway Medic
www.Gasolinealleyllc.com
www.technifoam.com - mass loaded vinyl barriers
Old Nov 19, 2001 | 08:19 AM
Ndo125's Avatar
I opened my door panel and It already has styrofoam in it.....
do you think I should install more sound insulation?
Does it usually come w/ styrofoam in the door panel?
fyi, mine is a GLE
Old Nov 19, 2001 | 08:25 AM
jmax
If you look carefully that styrofoam is only 9-12 inches wide and only on the bottom half of the door. You want to install foam that covers the entire panel.
Old Nov 19, 2001 | 08:59 PM
C-Dawg's Avatar
If you have ever seen the "eggshell" foam that's used to place on top of bed mattresses to make them softer, you can use that. If kind of looks like the bottom of an egg carton with all the grroves and dips in it. It is foam padding and will work great. That's what I used to do my doors and it worked amazingly well. Same method as mentioned above. Cut to fit, spray on adhesive and press and stick.
Old Nov 19, 2001 | 09:35 PM
jmax
Actually the mattress pad is what I use, and less than $10 for the whole pad at walmart
Old Nov 20, 2001 | 08:49 AM
C-Dawg's Avatar
That's exactly what I am talking about. I bought mine from like a Dollar General store for $7 or so for a twin bed size piece. You get a low of stuff for the amount you pay. It works really well.
Old Nov 22, 2001 | 09:51 AM
SWEETSOUND2001's Avatar
If you install egg shell foam inside the door, it will fill with moisture and rot or fall off. Or am I wrong?
Old Nov 22, 2001 | 03:57 PM
C-Dawg's Avatar
I really think that it depends on how much you use your windows. I sprayed scotch gaurd on mine, but I hardly use my rear windows at all. I just had to make sure that the front ones were properly coated.
Old Nov 23, 2001 | 05:56 PM
jmax
The water will drain more slowly out the drain holes, but will still drain. I have't had any excess water problems.
Mahmuth
Aug 16, 2024 08:23 PM
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
