The ONLY 4th gen bose replacement thread you will ever need
Old Mar 16, 2009 | 09:57 PM
95.maxima's Avatar
ok so i spent about 8 hours doing this. fiddleing around with wires, forums, internet, you name it i read it. and here is the answer to your questions.
if you have 4 new 6 1/2's, and a new headunit, you NEED to bypass the bose amps. but how you say? well here is the ultimate answer i couldnt find anywhere on earth:
yellow to red
green to purple
thats it. no more bose amps. PLEASE ask me questions i would love to answer them for you,
Old Mar 17, 2009 | 05:29 AM
djfrestyl's Avatar
Suspension Yoda
Ok, so what are those wires?
Old Mar 17, 2009 | 06:00 AM
95.maxima's Avatar
heh if you actually take everything apart it would make more sense but the wires are the input the amp and the output from the amp. and pretty much we had to figure out what is what in order to wire them together to skip the amp.
i had a few drinks in excitement last night of finishing so if its a little confusing im sorry. thats why i wanna answer questions.
Old Mar 17, 2009 | 12:34 PM
JSMax's Avatar
Sold
the colors of wires are the same for each speaker location?
Old Mar 17, 2009 | 12:37 PM
95.maxima's Avatar
yes they were actually. we did the front first which were the same. we had doubts the two backs would be the same as the fronts but they are.
it was rather nice once we got the first speaker wired.
Old Mar 17, 2009 | 01:36 PM
JSMax's Avatar
Sold
good to know. bookmarked for future reference.
Old Mar 17, 2009 | 01:38 PM
95.maxima's Avatar
while doing it i wanted to do a write up but i sadly forgot the camera. the amp boxes in the doors are perfect for hiding all the wire and everything.
i think im in love with my sound system now
Old Mar 17, 2009 | 04:50 PM
djfrestyl's Avatar
Suspension Yoda
Glad you figured it out on your own.
I am certain I've seen an in/out wire color diagram for 4th gen w/Bose on this forum before, just letting you know.
Old Mar 17, 2009 | 05:40 PM
95.maxima's Avatar
well after hours of scouring the internet this was the only thing i came across:
http://www.tamparacing.com/photopost...ing_colors.JPG
and its for an 02 which helped me none heh
Old Apr 7, 2009 | 10:48 AM
dashan's Avatar
Hohooooooo, this information is what I need.
Marked.
Old Apr 7, 2009 | 10:50 AM
dashan's Avatar
Is 6.5 inch speaker a direct fit in the front door oem hole?
Old Apr 7, 2009 | 02:44 PM
95.maxima's Avatar
Marked.
no problem.
and yes 6.5's fit right in with the fronts and the rears. the holes lined up almost perfectly but i think they might be slightly bigger than the plastic cup it screws into. but i just made it fit with no issues at all.
good luck!
Old Apr 9, 2009 | 01:01 AM
westy_2009's Avatar
where abouts are those wires? im trying to install a sony unit on a 1999 maxima GV, and when i connect the speakers (or what i thught are the speakers) no sound, so im guessing it has the bose amps... i wont be changing the speakers, just the head unit...
Old Apr 9, 2009 | 05:11 AM
djfrestyl's Avatar
Suspension Yoda
^^^ Read the stickies. Your situation does not apply to this thread. All you need is a specific Metra wire harness.
Old Apr 9, 2009 | 09:56 PM
CraigsMax01's Avatar
does this have to be done for the 5 gens? already installed the sub amp and sub. now for the highs
Old Apr 9, 2009 | 10:17 PM
2THEMAX98's Avatar
please help, i hope this is okay here...
im fairly new at this but i just installed my subs and im trying to install my 4 new speakers with an amp, now my cd player has 4 rca outputs for the highs and 2 rca's for the low's and i know im ganna have to bypass the bose amps but how should i wire the speakers to the amp in the back? i think what im going to do is run the wires from the cd player to the back but i dont know what wires to cut and wire up to the back? (i hope you guys know what i mean) im looking for a wiring diagram for my harness so i can know what wires are what, i cant really tell from looking at the harness to the cd player
Old Apr 10, 2009 | 06:01 AM
djfrestyl's Avatar
Suspension Yoda
First, proper spelling and punctuation is your friend. Use it, it helps.
2nd, let me clarify for everyone. Aftermarket HU, aftermarket 4ch amp, aftermarket subs. You are also installing 4 aftermarket speakers and want to utilize the factory speaker wiring?
Your Bose amps are in the front doors at the speaker, and are also on each rear speaker in the rear deck.
Either way, you have to run RCA's (6 channels worth) from your HU to your amp(s) in the back.
For your speakers, you have two options.
1. Run 4 sets of speaker wire from your 4ch amp to back behind your HU and enter into the speaker leads using your HU wire harness. You will then have to make sure you are taking the PRE-AMPED speaker wire in the door/rear deck and are wiring it directly to the speaker. You don't want to try to amplify an already amplified signal.
2. The easier/smarter way. Run speaker wire from your 4ch amp to each speaker directly.
Old Apr 10, 2009 | 12:06 PM
2THEMAX98's Avatar
sorry i had just got off of work and i was really tired. thanks for the help.
i probably will just wire the speakers directly to the amp and take out all the bose equiptment. should i use the bose harness i have now or should i use a non bose harness, or does it matter?
Old Apr 10, 2009 | 04:48 PM
djfrestyl's Avatar
Suspension Yoda
Doesn't really matter, all you need is +12v, acc, ground, power antenna from the harness. Nothing else gets connected.
halfpol
Oct 17, 2022 12:16 PM
Finkle
Sep 27, 2015 09:53 PM
MaxStock
Aug 12, 2015 08:33 AM
MikesChevelle
Aug 6, 2015 11:36 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
