Steering wheel controls... Help
Old Apr 6, 2009 | 12:25 PM
maxs4life's Avatar
Does anyone have an aftermarket radio with an aftemarket controls
I want to get an eclispe avn6620 and i need the swi ecl2. Does anyone have this..
Need intput..
Steering wheel controls arve very important to me,,, Help
Old May 5, 2009 | 02:19 PM
cpuguy06's Avatar
I would be interested in this too. I have the AVN6620 and would be nice to use the steering wheel controls. Is the PAC box needed?
Old May 5, 2009 | 05:53 PM
07Maximan's Avatar
I had one with my Pioneer Avic 700 BT and it work pretty good.The only problem was that is lagged a little,but I think thats because the Pioneer pretty much sucked.I just bought an Eclipse AVN52d and Ill be installing a Pac with it as well.Bottom line...they work and are worth the money.One thing though,if you not familiar with wiring Id suggest leaving the install to a professional.It has to tap into certain wires and you also have to use 2 very small resistors.Not a job for a newbie.
Old May 5, 2009 | 06:22 PM
djfrestyl's Avatar
Suspension Yoda
^^ Agreed. Retaining your steering wheel controls is very simple with the correct PAC module.
^^ DOUBLE agreed, if you don't know what you're doing, pay someone to have it done. If you understand electronics/wiring, you could probably get by though.
Old May 5, 2009 | 09:11 PM
Buy a Toyota. No adapters necessary, and it works flawlessly with the steering wheel controls.
OP. The part you mentioned will do the trick.
Old Jun 23, 2009 | 10:56 PM
maxlvr31's Avatar
Need intput..
installed with alpine head unit. Just make sure you have a good ground. I grounded mine to a nut behind the a/c controls that lock a little clear plastic box in place. Also, to make things easier, I soldered a piece of wire on either end of my resisters and then crimped the end of the wires in place with butt connectors. Hope this helps.
JoshG
51
Sep 21, 2015 10:41 PM
Bonka
Sep 14, 2015 11:18 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
coasterswim
Sep 2, 2015 07:43 AM
