CD Deck problems
Old Jul 22, 2009 | 09:38 AM
NY04Maxima's Avatar
CD Deck problems
I have a 04 Max with a Bose system. Everything works fine except that my CD deck seems to be dirty. When I play a CD it will skip as if the CD is scratched. It does this with every CD so I know the problem is the deck.
I was thinking of using a regular CD deck cleaner to clean it, but I think I read somewhere that a regular deck cleaner should not be used to clean the Bose system. What do you guys recommend?
Old Jul 23, 2009 | 07:13 AM
djfrestyl's Avatar
Suspension Yoda
Where did you read that? An optical CD laser is the same for any drive, regardless of manufacturer.
Old Jul 23, 2009 | 12:50 PM
Calcvictim's Avatar
I am not saying it's true but it might be because of the way the cd changer transports the disks, am I way off base?
A cleaning cd has a very small brush attached to it with the bristle length being the same as the distance between the cd and laser, is it possible for the bristles to get caught in certain transport mechanisms?
Also I am not sure if the cleaning cd would ever work because in order for it to clean it needs to play a certain track, not sure if you can get to that track if the lens is dirty.
Old Jul 24, 2009 | 05:59 PM
eluther3's Avatar
I have a similar problem with my CD changer. CD sound is garbled and inconsistent. I've also noticed the sound changes if I brake hard or take a corner fast.I bought a cleaning CD with the small brushes. It took me 10 tries to get it to run. After running once, it shut down and I haven't been able to get it to play again. Wouldn't recommend it.Any one out there no any other options for cleaning the Bose CD player.
Old Jul 26, 2009 | 01:57 PM
djfrestyl's Avatar
Suspension Yoda
Cleaning the Bose CD player?
Very easy - replace it.
Old Jul 30, 2009 | 09:23 PM
eluther3's Avatar
Would like to - I'm saving my coin to put in a double din CD/nav system, but that's probably six months away. Any other suggestions for cleaning the CD player in the meantime. It's starting to really get on my nerves!
Old Jul 31, 2009 | 10:56 PM
djfrestyl's Avatar
Suspension Yoda
Just get a standard deck and a windshield mount navi. Cost effective, navi is more versatile. Plus you can fix your audio sooner.
Old Aug 3, 2009 | 11:26 PM
NY04Maxima's Avatar
Calc, you reasoning is on point. The small brush is the reason why using a regular CD cleaner will not work for cleaning the deck.
I found a product that is made specifically for car audio decks. It is made by Maxell - it is called - Maxell Auto CD- Cleaner.
I am yet to try the product. I will post the results once I get it and try it.
user 11122324
42
Jul 18, 2022 03:35 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
zmcneely13
Sep 26, 2015 02:26 PM
Noela
Sep 26, 2015 08:22 AM
