crazy dimming headlights
Old Aug 2, 2009 | 07:41 PM
cmd26's Avatar
i just added a subwoofer and amp to my car, i was wondering if i got a cap on it should that stop my headlights from dimming or is there a bigger problem
Old Aug 3, 2009 | 09:59 AM
bigpopaj369's Avatar
most guys are guna tell u a cap is a bandaid wich is true but it does do its job and it should greatly reduce or stop the dimming.another good way is to do the big 3 wire mod. i just was reffered this buy someone on here i havent done it on my car but i have done it on someone elses.heres a link for instructions http://www.isyougeekedup.com/the-big...iring-upgrade/. in there system it completely eliminated all the dimming and the amp seems runs better from what he said. im sure more guys will will tell u other things but from my experience both the cap and the big 3 mod work just fine
Old Aug 13, 2009 | 01:51 PM
dnozzle2789's Avatar
or you could just get a better alternator ???
Old Aug 13, 2009 | 06:03 PM
i talked to a long radio employee he said upgrading the wiring like the big 3 mod and adding a cap is what he would reccomend and they do it on almost every install. he said yes theres alot of people bashing on caps but they DO work and upgrading your alternator is really only needed if u are pushing ALOT of power. upgrading the battery is another good way to help the dimming.
Old Aug 14, 2009 | 12:46 AM
AscendantMax's Avatar
screw the cap, do the big 3.
also, make sure you ground the amp to the chassis, and that the grounding point is free of paint/dirt/grime.
Old Aug 14, 2009 | 06:15 AM
ok so not tryin to threadjack but 4awg ok to use for the big 3? i did my friends car with i believe 0awg but to me it seemed overkill for what he was running
Old Aug 14, 2009 | 09:34 AM
4awg will be fine.
Old Sep 24, 2009 | 10:12 AM
mantle7yanks3's Avatar
based on my experience the big 3 wire mod will help much much better than a cap
Old Sep 24, 2009 | 12:03 PM
cashoit's Avatar
has anyone done the big 3 mod....does it harm the car...i know that it allows more current to flow faster from the battery, alt, ground....but if its better why didnt nissan do it in the first place.
I didnt do the big 3 but i have a cap and it works...u cd also try lower the amp a tad bit hehe
Old Sep 24, 2009 | 05:38 PM
^^^ it doesnt hurt anything it only helps, ive done a few big 3 mods its a huge improvement, the stock wiring is fine for powering the car and all the stock equipment u only need to do the big 3 when u add an aftermarket system to improve the grounds and power supply for the extra strain on the cars electrical system
Old Oct 5, 2009 | 05:42 AM
Professor's Avatar
big 3 +1
Old Oct 5, 2009 | 07:24 AM
Rood's Avatar
Caps are junk, I learned the hard way. I upgraded my wiring and haven't had any problems.
Old Oct 5, 2009 | 07:56 AM
BOOTZ's Avatar
Upgrading the alternator is the best solution. Check out excessiveamperage.com Nathan Peddicord is the guy to talk to. I got a H/O alternator for $300
gavin68
Sep 18, 2021 12:36 PM
doctorpullit
Oct 28, 2019 10:58 PM
Garrettz459
Sep 28, 2015 02:50 PM
Noela
Sep 26, 2015 08:22 AM
