fuses keep blowing
Old Aug 17, 2009 | 07:34 AM
cmd26's Avatar
fuses keep blowing
the fuse near my battery keeps blowin do i need a bigger fuse, im currently using a 60a fuse with a 4 gauge wire rockford fosgate p5002 brigded with a crewin vega 124 12" sub ported
Old Aug 17, 2009 | 07:35 AM
cmd26's Avatar
i was told by my bro to get an 80a fuse
Old Aug 17, 2009 | 08:08 AM
Calcvictim's Avatar
what happens when the fuse blows, are you playing music, are you stressing the amp?
the reason I ask is to make sure you do not have a short before upgrading the fuse.
Old Aug 17, 2009 | 08:19 AM
cmd26's Avatar
first the two on the amp would blow then the fuse near the battery would blow, all this while music is playing, i check the power cable its seemed fine, wut else should i check
Old Aug 17, 2009 | 12:52 PM
nismos14's Avatar
§è~® f®ÈÄk
Go to an 80 and see what happens.
nismos14's Avatar
§è~® f®ÈÄk
nice sub btw, I'm running the same one and it's ear sex.
Old Aug 18, 2009 | 11:58 AM
djfrestyl's Avatar
Suspension Yoda
Agreed, up the amperage on the fuse. But if the ones on the amp itself are blowing, sounds like a wiring issue.
Old Aug 26, 2009 | 01:16 PM
cmd26's Avatar
i have no clue y i cant get my system to work, now the problem is if i turn the gain **** on my amp i dont hear anything from the sub until its turn more than half way then my amp goes into protect but it doesnt feel hot like its overheating, it also does this with the gain real low. even with the gian and evereything turned down if i go pass 20 on my volume my amp goes into protect.
Old Aug 26, 2009 | 01:17 PM
nismos14's Avatar
§è~® f®ÈÄk
Absolutely sounds like a wiring issue on how the sub is wired.
Old Aug 26, 2009 | 01:19 PM
cmd26's Avatar
it a dual voice coil and i wired it to use all the voice coils
Old Aug 26, 2009 | 01:21 PM
nismos14's Avatar
§è~® f®ÈÄk
In parallel? In series? For that amp you need a final 4 ohm load hen bridging.
Old Aug 26, 2009 | 01:50 PM
cmd26's Avatar
series
tarun900
19
Dec 20, 2021 06:57 PM
leatherneck
Sep 30, 2015 09:16 PM
Noela
Sep 26, 2015 08:22 AM
