Quick ? about some aftermarkets
Old Aug 18, 2009 | 08:15 AM
wickedmax13's Avatar
I just blew one of my 6x9s (I think its a 6x9) in my 2005 SE with standard stereo system. Im thinkin these speakers since most factory speakers are a 4 ohm speaker. I bought some nice infinity speakers, but they run at 2 ohms...is this going to cause problems with my factory head unit? If so, is there an easy fix to this problem or should I take them back and get different speakers that are 2 ohm? Sorry about the NEWBIE ? ha
Old Aug 18, 2009 | 10:43 AM
Calcvictim's Avatar
the answer was 5 threads below.....just look
http://forums.maxima.org/audio-elect...ard-radio.html
Old Aug 18, 2009 | 11:00 AM
Ya I saw that thread but it just had a possible outcome of what would happen...not a way to solve the problem on running a 2 ohm speakers on a 4 ohm expectant head unit. I want to know if there is an easy way to use 2 ohm speakers on a 4 ohm system set-up without it causing any problems? And also while I'm here, is still having my blown speaker hooked up and sounding like shat going to hurt my system at all? Only until I get a chance to swap em out with the new ones. Thanks in advance
Old Aug 18, 2009 | 11:28 AM
Is this how to do it??? Did some more research and want to run it by some people...instead of the subs n the picture it will be my speakers and i will just hook up the positive and negative into the factory amp like shown.
http://akamaipix.crutchfield.com/ca/...2-ohm_mono.jpg
Old Aug 18, 2009 | 11:44 AM
Calcvictim's Avatar
stop being a cheap ***, get speakers that will work
1)if hooked up as pictured you will not have stereo
2)you will be sending half the power to each speaker and considering that the factory system is puny at best it is not a viable choice
no there is no way around it, either deal with a poissible scenario that I described or get speakers that work
Old Sep 24, 2009 | 10:10 AM
mantle7yanks3's Avatar
wire the speakers in series to 4 ohms... check out this link for help http://www.the12volt.com/caraudio/wo...s.asp?Q=4&I=81
Old Sep 28, 2009 | 08:42 AM
01GLEMist's Avatar
They will work. And infinity's aren't 'cheap' speakers by most regards, minus audiophiles of course. Wire them up as you normally would, and take a multimeter to behind the headunit and test the resistance (ohms) on that speaker. It should be damn near 3.5 or more ohms. Which is fine. Some infinity models take impedance rise and other factors into account, so that you're not left with 5ohms or higher at the headunit.
JakeOfAllTrades
Oct 5, 2015 10:40 AM
sliptap
Sep 30, 2015 05:57 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
