What amp to get in the $200 range ??
Old Sep 24, 2009 | 09:58 PM
Infowire's Avatar
So i ordered a single 12" Alpine SWR-1242D Type-R Sub, now i need an amp and a box, suggestions appreciated =)
I want to hear how this sub will sound and i might get a second one if this one isn't loud enough by itself.
Here is the amp im looking at:
http://www.crutchfield.com/p_500MRPM...00.html?tp=115
I listen to electronic music, and i like clear lows and nice highs bass =)
Old Sep 25, 2009 | 04:11 AM
Jreed2008's Avatar
If i read correct the sub you listed is a dual 4ohm and rated at atleast 500w and both coils have to be used so its recommend that your giving atleast 250w to each at 4ohm coil which the amp you list isn't capable of. So you might have to increase your budget if you want decent output from the sub
Old Sep 25, 2009 | 06:03 AM
Infowire's Avatar
What would you suggest?
Size 12 -inch
Impedance 4 ohms
Cone Material Kevlar Reinforced Pulp
Surround Material Santoprene rubber
Sealed Box Volume (cubic feet) 0.57 - 1
Ported Box Volume (cubic feet) 0.75 - 2
Port diameter (inches) 3
Port length (inches) 9.9
Free-Air No
Dual Voice Coil Yes
Sensitivity 85 dB at 1 volt
Frequency Response 25 - 500 Hz
RMS Power Range (Watts) 200-500
Peak Power Handling (Watts) 1500
Top Mount Depth (inches) 7 5/8
Bottom Mount Depth (inches) 8 7/16
Cutout Diameter or Length (inches) 10 13/16
Vas (liters) 45
Fs (Hz) 29
Qts 0.47
Xmax (millimeters) 18.2
Parts Warranty 1 Year
Labor Warranty 1 Year
Old Sep 25, 2009 | 05:42 PM
Infowire's Avatar
bump... anyone ??
Old Sep 25, 2009 | 07:14 PM
mwright1000's Avatar
JL Audio 500/1
Old Sep 25, 2009 | 09:00 PM
Jreed2008's Avatar
you can get a four channel amp thats rated atleast 250w X 2 @4ohms and bridge both channels into each coil. So the Polk PA500.4 or the JL G450 comes close to your price range and should do the trick. PS... your life would have been easier with the 1222D model sub much easier to power
Old Sep 25, 2009 | 09:01 PM
Infowire's Avatar
ts like 600 $$!!! blah i don't have that much money i wish..
http://www.crutchfield.com/p_2064SX9...-2.html?tp=115
how about this one ?
Old Sep 25, 2009 | 10:45 PM
MoncefA33's Avatar
I can get you an Infinity REF1600A mono amp for $190 shipped.
http://www.crutchfield.com/p_108R160...nity+amp&ssi=0
600w RMS @2ohms, should power that TypeR just fine.
PM me and we'll talk.
Old Sep 26, 2009 | 06:03 AM
Infowire's Avatar
http://cgi.ebay.com/NEW-ALPINE-MRP-M...d=p3286.c0.m14
i think this one has some more boost =)
Old Sep 26, 2009 | 06:46 AM
Infowire's Avatar
just bought a
ALPINE PDX-1.600 CAR MONO POWER DIGITAL AMP
got a good deal on it $240 = )
Old Sep 27, 2009 | 10:19 AM
FlipCpt45's Avatar
Originally Posted by Infowire
just bought a
good amp
lets just say bestbuy gets that same price
Old Sep 30, 2009 | 12:42 PM
Maxin03's Avatar
Originally Posted by FlipCpt45
good amp
i have the same sub as you and i bought the mrp-500 and it good as anything.. and you can never beat discount when it comes to car audio reason why im still here lmao
Old Sep 30, 2009 | 01:39 PM
MoncefA33's Avatar
Haha x2 I'm running the M500 on a 12" Infinity Perfect.
Old Sep 30, 2009 | 02:33 PM
phunGuy11's Avatar
i had a single 12" type-r pushed by a mrd-605 alpine amp in a sealed box. The set-up was so clean, providing very tight bass. You're prob not going to find another sub that can give you a clean bump, a single "R" wouldn't rattle the car's window next to you at a light, but able to shake your rear-view around.... so pissed after my set-up got stolen. My two P1's are equivalent to a single type-r, but then again they are only powered by a crappy Profile amp. If you're looking for serious stuff to shake your house 5 blocks down, type-r is NOT what your'e looking for, better get a L7 or something along those lines. If you want that bump with clarity, stay with single type-r in sealed box. I've hear the ported box does pretty well but i haven't heard it.
Anyways, i would check on craigslist for an amp, just make sure it works before you buy it. If you don't mind getting a used amp, you can prob find a JL 500/1 for around $200 or a RF 500w amp. Trust me, you'll regret it if you get a crappy amp, i bought a used set up of the p1's powered by a "600W" profile amp for $100, and those subs aren't even pushed to it's potential. I'm going to get a better amp soon though.
If i were to buy new, i'd prob get this:
http://www.crutchfield.com/p_575R500...owAll=N&tp=115
Miket2006
Mar 1, 2021 03:55 AM
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Socalstillen
Sep 26, 2015 12:01 PM
