5.5 Gen 2002 Maxima SE XK05 vs. PKN2 with Viper 5901
Old Dec 12, 2009 | 10:13 AM
Skorp1on's Avatar
Sorry for the newbie question but I am planning to add remote start/alarm to my 5.5 gen (2002) Maxima SE in with Viper 5901. Could somone let me know the difference between XK05 and PKN2? Perhaps PKN2 is mainly for Nissan cars and XK05 is more "universal'?
I don't want to sacrifice one of my keys so I would prefer to bypass the transponder.
Thanks.
Also, if somone had experience installing Viper 5901, let me know how it took to do the job. I've experience installing RS for my 1994 Camry before without transponder bypass so I was able to located necessary wire by color code, test light, etc. So now I am attempting for my 5.5 gen...
Old Dec 14, 2009 | 04:08 PM
w8lifter21's Avatar
Process will be the same as in your camry, except for a few extra wires for the bypass. Main benefit of the XK05 over the PKN2 is that it will work with push to start nissan/infiniti. You will be fine with either. Let me know if you have any other questions, I'm a Directed dealer and do remote starts for a living
Old Dec 15, 2009 | 08:48 PM
Pearl96Max's Avatar
I tend to get a bit irritable
PKN2 is for Nissan only. XK05 is for an abundant amount of others, but will have to be flashed to PKN2 3.0 If your not capable of flashing, then stick with the PKN2. I have always stuck with the XK05s and they have never failed me. XK05s offer D2D and PKN2 does not, makes the install a bit quicker for prep time and easier for wiring.
Old Dec 16, 2009 | 07:44 PM
Skorp1on's Avatar
Thanks Pearl - based on my research, I found that XK05s doesn't normally come standard with all the differnent types of firmwares already flashed out of the box. I am capable of flashing to other firmwares but would need to get my hands on Bootloader. I was also considering cost difference between PKN2 and XK05. Although XK05 by itself seems cheaper then the PKN2, the average joe would still have to cough up add'l money for a Bootloader to flash it to our Gen 5.5 application. In the end, XK05 and PKN2 end up costing about the same but XK05 may have a slight advantage with D2D and "universal" application for other vehicles.
Old Dec 16, 2009 | 07:59 PM
Skorp1on's Avatar
Thanks in advance w8lifter21. There are a fews thing I am worry about as compared to wiring up my Camry:
1. door locks/unlocks - any need to add resistors/diodes to get the double pulse?
2. the Viper 5901 manual says to wire the NSS input wire to Ground. What is recommendation for 5.5 gen max? Wire NSS input to ground or to Pin 44 at the ECU?
Old Dec 18, 2009 | 06:41 AM
mendon99's Avatar
tastey wheat
1. no resistors or anything for our nissans, the double pulse is all in the programming process.
2. If you have a manual, wire the NSS wire to the NSS at the ecu. If you have an auto, just ground it. This is to prevent accidental starting in gear (for a manual)
Finkle
Sep 27, 2015 09:53 PM
tcb_02_max
Sep 11, 2015 12:23 PM
fastcarny
Aug 12, 2015 03:50 PM
MaxStock
Aug 12, 2015 08:33 AM
yat70458
Aug 3, 2015 01:16 PM
