Bose Speakers w/ Aftermarket HU
Old Dec 4, 2001 | 02:08 PM
seawolf14's Avatar
Have 93 se w/ bose system. Bought the car used and it came with aftermarket Alpine HU. There is a ton of distortion which I assume is caused by an overload of power, i.e. the amplifier from bose, and the amplied signal out of HU. Is there way a way to detach/ground the bose amplifiers and connect the HU directly to the bose speakers? I had heard that the impedence on the bose speakers would create a problem if done this way.
Old Dec 4, 2001 | 05:30 PM
ny96max's Avatar
for $50 they sell a bose-aftermarket interface unit. It converts the new hedunits power to work with the existing bose amps/speakers work great too BTW!
Old Dec 4, 2001 | 05:35 PM
seawolf14's Avatar
Really, I did not know that. IS that somethign you buy from Nissan or from a car audio shop.
Thanks for the help.
Old Dec 4, 2001 | 06:00 PM
maximadave's Avatar
detailerdaveb@gmail.com
Nissan would not have this part. Most car audio shops do carry them.
Old Mar 12, 2002 | 03:41 AM
luism's Avatar
i just put in a pioneer headunit in my bose system.all you need is a bose oem adapter from crutchfield $50 or if you go to bestbuys you get a headunit adapter and an antenna adapter(you need both) for less than $40 bucks.good luck!!
Old Apr 6, 2002 | 04:59 PM
pj93max's Avatar
I'm getting an aftermarket HU - JVC SH 707 and I want to do the same thing - hook it up to my stock bose system.
What kind of bose adapter did you buy? from where ?
by using this adapter, are you in any way, decreasing the sound
quality ?
Old Apr 6, 2002 | 08:47 PM
luism's Avatar
luism
you're not affecting the sound quality at all. All you need is the headunit adapter and the antenna adapter. I got mines installed at bestbuys which isn't the most reliable place and it only cost me like $40 for both adapters and $50 for the installation.It sounds great because the new hu puts out a lot more than the bose hu with roughly the same amount of ohms.
chisam14
Nov 6, 2018 08:56 PM
magiconthetire
Oct 26, 2015 09:03 PM
sliptap
Sep 30, 2015 05:57 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
