Need Info How To Run Wire To Battery From Amp
Old Dec 6, 2001 | 02:05 AM
skyrocker
HOW CAN I RUN A WIRE TO THE BATTERY, WHERE IS THE FIRE WALL,AND IS THERE A WAY TO AVOID CUTTING THRU IT, OR DRILLING, IS THERE A WAY TO RUN THE WIRE
HOW DO I FIT 6'9'S IN THE BACK, I NEED TO FIT THEM
I ALREADY BOUGHT THEM HEHE
94 MAXIMA..
Old Dec 6, 2001 | 09:41 PM
THAWABUTT's Avatar
The fire wall is the big fat heat shield that sits between you and your engine, all it is is a big hunk of metal, probably some synthetics in there too. You could look for a grommet in your firewall to pull the wire through, in case you don't know what a grommet is it is a usually a piece of rubber or plastic that protects wires or cables running from the engine compartment to the inside of the car. When you look in there you should see what I am talking about. An easy place to run a wire is would be where your radio's power cable is , or even through the grommet where the clutch cable is, if it has one. As for the 6x9's you should've bought 6½'s, J/K I am really fond of 6½'s, I wouldn't know, but someone else should.
Old Dec 7, 2001 | 02:01 AM
skyrocker
is it a wise idea to cut the back and get the 6'9's
Old Dec 7, 2001 | 09:19 PM
NICOLE's Avatar
just drill a hole throught the fire wall it is a very quick and easy.and once u made the hole make sure that u seal around the wire just in case u made the hole 2 big
Old Dec 7, 2001 | 10:49 PM
atulb84's Avatar
Re: Need Info How To Run Wire To Battery From Amp
dont type in all caps
94 MAXIMA..
Old Dec 8, 2001 | 04:17 AM
jim90gxe's Avatar
94 MAXIMA..
Remove the splash shield from the fwd drivers side wheel well. You will see a big wire bundle w/grommet going to the interior. Cut the grommet in such a way so you can pass the amp wire throught it. Be careful not to cut any another wires.
good luck
Old Dec 9, 2001 | 02:19 AM
THAWABUTT's Avatar
This peson said they didn't want to drill.
6spd4dsc
May 9, 2022 12:30 PM
melteye
May 16, 2016 12:02 AM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
doobadoo
Aug 15, 2015 06:43 PM
