Installation questions
Old Mar 14, 2010 | 10:18 PM
Shoot.'s Avatar
How do I amp the door components, how do I get the door panels off, and how easily does the carpet come up off the floor? I searched and virtually found nothing or very little for my first two questions
Old Mar 15, 2010 | 12:05 AM
AscendantMax's Avatar
you want to add an aftermarket amp to power the factory stuff or aftermarket gear?
door panels aren't too hard, what year maxima?
Old Mar 15, 2010 | 12:27 AM
Shoot.'s Avatar
all new components and comp amp, and I have an 01
Old Mar 15, 2010 | 01:12 AM
Nismo215's Avatar
just get a flat head, the panels should pop off easily. And the floor isn't too hard either its held on by the panels or if it's under a seat remove the seat, so if you pop off the panels the floor should be able to be lift up
Old Mar 19, 2010 | 06:05 AM
djfrestyl's Avatar
Suspension Yoda
Even though you searched, you didn't search enough. The info is definitely there.
00-03 door panel:
Remove trim ring around door handle. Remove plastic cap at front of door - and screw behind it. Remove small circular cover inside door handle 'cup' - and screw under it. Remove cup itself. Disconnect/remove courtesy light at bottom of door panel. Feel for opening at bottom of door panel, use fingers to pull outwards to pop clips. Disconnect wire harnesses as necessary. Lift door panel upwards over window ledge.
For the components, you're going to have to drill through the door jamb to get a wire into the door. It's a molex plug and you CANNOT fish wire through the connection on the car side. Once you get it out of the car, you can make a slit in the grommet and fish it through into the door. Or, locate the wires before they enter the door. The wire information is definitely available - search for it.
OP, where are you located? I do installs and am located in NJ.
Old Mar 22, 2010 | 05:10 PM
Shoot.'s Avatar
I'm in Alabama, I wanted to DIY on the components, but all that.. damn
Old Mar 23, 2010 | 05:08 AM
djfrestyl's Avatar
Suspension Yoda
Hehe - it's not all that hard. I can get a door panel off in about 35 seconds.
Old Mar 27, 2010 | 04:48 PM
Shoot.'s Avatar
Another question, how do I install a double Din in my 01, do I need a kit?
Old Mar 27, 2010 | 08:12 PM
Andrew's Avatar
yes, you will need a kit for that
Old Mar 27, 2010 | 10:09 PM
Shoot.'s Avatar
purchased this one for the grand total of 7.10
http://www.amazon.com/Metra-95-7417-.../dp/B000K50GF4
Old Apr 1, 2010 | 12:36 AM
Shoot.'s Avatar
I didnt even have the right wiring harness
Old Apr 1, 2010 | 12:53 PM
Shoot.'s Avatar
whats up with the wiring harness?
Old Apr 1, 2010 | 04:34 PM
djfrestyl's Avatar
Suspension Yoda
I dunno, what's up with it?
Old Apr 1, 2010 | 07:45 PM
Shoot.'s Avatar
the one that came with the deck isnt the right one, it came out of a subaru, where can I get one?
Old Apr 1, 2010 | 07:47 PM
djfrestyl's Avatar
Suspension Yoda
Are you Bose or non-Bose?
Which HU did you buy?
Old Apr 1, 2010 | 08:33 PM
Shoot.'s Avatar
non bose here, I got a Pioneer f900bt
Old Apr 4, 2010 | 08:02 AM
djfrestyl's Avatar
Suspension Yoda
You need a Metra 70-7550 as your wire harness. You also need an antenna adapter and dash kit.
Old Apr 4, 2010 | 08:43 PM
Shoot.'s Avatar
ok, I have everythign but the antenna adapter, I dont listen to the radio much so I dont really need it
Old Apr 5, 2010 | 06:40 AM
djfrestyl's Avatar
Suspension Yoda
Seriously? For the $6 an adapter costs? That's terrible logic.
Old Apr 5, 2010 | 08:49 PM
Shoot.'s Avatar
well im also broker than chuck right now lol, its either get the antenna or pay for gas, besides, ill likely be opening everything back up in about a month or so to install my amps/subs
Old Apr 9, 2010 | 01:41 PM
Shoot.'s Avatar
I seriously have no idea how to install components and run wires for them, how do I do that?
Old Apr 10, 2010 | 02:41 PM
djfrestyl's Avatar
Suspension Yoda
I think you should take it to a shop.
Old Apr 10, 2010 | 10:13 PM
ampire's Avatar
To the OP, if you want to do the wiring to the doors nice and clean, I recommend cutting a tiny hole in the rubber gromets where the factory harness exits, heat shrink a section of speaker wire, then slide the speaker wire alongside the factory wiring. The heatshrink will both protect the wire and make it look very close to factory. Then use black cable ties to zip the two harnesses together.
Old Apr 11, 2010 | 02:10 PM
djfrestyl's Avatar
Suspension Yoda
It seems that even these ^^ instructions are more complex than the OP's installation skill level.
Old Jun 15, 2010 | 05:37 PM
JordanBertini's Avatar
you should take it to a shop that will do it for you
Old Jun 16, 2010 | 09:53 AM
tigersharkdude's Avatar
retard
PH98I30
Jan 9, 2025 08:08 AM
JRod28
Dec 29, 2023 09:56 PM
mikekay
Aug 10, 2015 12:52 PM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
