2 10" JL Audio W3s...JL 250/1 Amp or JL 500/1 Amp?
Hey guys,
I've had my box sitting in my room for like 2 months now. I really got to get this stereo done so I can get it out of my bedroom. I'm looking into a JL Audio 250/1 Amp or a JL Audio 500/1 Amp. Which one do you think will be better suited to power my 2 10" JL Audio W3 subwoofers?
Everything else is decided on...I just need to decide on which amp for the subwoofers and then go buy it all. Any suggestions/help would be appreciated.
Thanks,
-Nick
Thanks,
-Nick
Re: 2 10" JL Audio W3s...JL 250/1 Amp or JL 500/1 Amp?
Originally posted by Nick97SE
Hey guys,
Thanks,
-Nick
Hey guys,
Thanks,
-Nick
Great guys! I think I'm gonna go with the 500/1. Someone in the past told me that the 250/1 would be more than enough but they must've thought I was only using 1 W3 sub.
Anyways...I know have my whole system planned out! I think I'm gonna wait until after the holidays to get the stuff. Hopefully I'll get a nice sum of money for Christmas and my birthday...which both fall on the same day!
Thanks for your help!
-Nick
-Nick
Originally posted by jmax
Will the 500/1 deliver 500 watts at 1.5 ohms? If so then that's what you want. Or at least what I would want. 250 watts per speaker.
W3 has three options for the voice coil impedance.
If you get dual 2 ohm you could run three coils in series, another three in series and then parallel those two sets for a net 3 ohms. If you get dual 4 ohm you could run each sub in series and parallel the three subs for net 2.7 ohms. If you get dual 6 ohm you could run each sub in series and then parallel the three for a net 4 ohms.
the 250/1 would push them put to get full potential i would go with the 500/1 it will sound great i know a guy that has that setup in his cls and it pounds harder than your probably expecting
Hey guys,
Thanks,
-Nick
Hey guys,
Thanks,
-Nick
Originally posted by jcy98maxse
which one of these would be the best in sound quality and loudness. is there even much difference between these 3 setup?? I understand that by getting lower in ohms you give up quality is that correct>?
popdedop
Sep 11, 2015 11:17 AM
