power wire not getting power some times.
Old Aug 25, 2010 | 07:54 AM
TravisCadello's Avatar
i took it back to shop who installed it and they said its getting power and i said well it gets power then i get down the road and it turns amp off. i bought new amp and same problem then he says i need to upgrade my fuse holder and wanted 40 bux to get me a 200 amp one from a 80amp fuse. will this really cause the wire to loose power?
i put my own wire and can bass all day on it no problems the one they installed is a fat 4 gauge red wire.
Old Aug 25, 2010 | 09:16 AM
MadMax07SL's Avatar
You're talking about power directly from the battery is having the problem, not the remote start wire, right?
Got to be around some of the connections somewhere, at the fuse block, right on the battery, check for corrosion under the hood.
Are you certain it's not the remote start wire that's failing to signal the amp on? And double check all the ground connections as well.
You know, a little more detail about the setup would help if you're looking for suggestions.
Old Aug 25, 2010 | 10:08 AM
im talking about the fat positive wire from battery to amp. the remote and ground work fine im running a getto wire to the battery and it will bass all day. i think im gonna bypass the fuse under the hood. and no corrosion it was installed like 4 months ago and looks all clean still.
Old Aug 26, 2010 | 12:46 PM
AscendantMax's Avatar
Try replacing the fuse. if your using an AGU fuse, the end caps can break off from the strip of wire in the middle. so the fuse may look intact, but is just making sporadic connections due to the cracked connection at the caps.
Old Aug 26, 2010 | 07:41 PM
mendon99's Avatar
tastey wheat
x2 replace the fuse with a brandy new one. there are a lot of cheap brand fuses out there some don't even work right out of the box
Old Aug 27, 2010 | 09:13 AM
kool its fixxed now thanks. cant believe a fuse would cause that problem lol. i figured a fuse either works or it dont not intermittent lol.
Old Aug 27, 2010 | 09:15 AM
BOOTZ's Avatar
I used to see that a lot with the Rockford fuses.
Old Aug 28, 2010 | 02:21 PM
yeah, GOOD fuses either work or it doesn't. the cheapo ones however...can be crazy like yours.
glad you fixed the problem though!
The Frye
Sep 2, 2021 11:03 AM
