Audio panel removal
Old Dec 17, 2001 | 02:03 PM
il2's Avatar
il2
Audio panel removal
Doe’s anybody know how to take off front panel on 2001Maxima?
I wont to replace the factory radio (1 DIN with the pocket).
I lifted bottom, but the panel’s top didn’t come out.
I don’t wont to force it.
Old Dec 18, 2001 | 03:02 AM
Tony Fernandes's Avatar
Re: Audio panel removal
I am curious about this as well.
Tony
Old Dec 18, 2001 | 03:47 AM
Gunner's Avatar
what part didn't come out?
you have to remove the center air vents. the first time is always the hardest. just pull straight up a bit then out.. there are screws behind that.
then remove the panel around the shifter with a small flathead. the are snap fit pieces (4 or 6) around the edges, be careful not to make scratches.
Old Dec 18, 2001 | 05:40 AM
2002 SE TX's Avatar
Be _very_ careful pulling out the vents. You have to pull really hard, so don't be scared, but be careful where you grab the vents. On my '97 Max I pulled too hard near the little "vanes" that direct the air out of the vents, and they all fell out! They're just snapped together so they can move freely. I had a fun hour putting them back together!
Old Dec 18, 2001 | 10:18 AM
il2's Avatar
il2
Re: Re: Audio panel removal
I understood, thank you.
Did you use special tools?
Old Dec 18, 2001 | 10:29 AM
il2's Avatar
il2
What tools Did you use?
I am definitely afraid to scratch the panels,
especially when my baby 6 month old.
Old Dec 18, 2001 | 01:10 PM
Gunner's Avatar
sorry.. i forgot to mention that the panel around the shifter has one screw to remove. in the tray, pull out the plastic insert. under that there is one screw to remove. this is probly why you couldn't remove the panel...
Old Dec 18, 2001 | 03:58 PM
il2's Avatar
il2
OK.
Did you use installation kit?
Old Dec 18, 2001 | 04:00 PM
Gunner's Avatar
Re: Re: Re: Audio panel removal
OK.
yes i used the one from crutchfield... like 28 bucks for all the stuff
Old Dec 18, 2001 | 04:07 PM
il2's Avatar
il2
Re: Re: Re: Re: Audio panel removal
What is purpose of the kit?
And thank you so much for your help.
Old Dec 18, 2001 | 11:10 PM
Gunner's Avatar
Re: Re: Re: Re: Re: Audio panel removal
the kit includes the plastic thingy to insert a single din player, a antenna adapter, and a wiring harness. 28 bucks for all pieces if i remember correctly.
my03maxima
Jul 28, 2024 07:40 AM
Fbana41
Aug 29, 2016 12:18 PM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
