Can't stop Battery corrosion
Old Feb 14, 2011 | 09:33 AM
MadMax07SL's Avatar
Positive battery post is constantly covered in corrosion. Not sure how to stop it. I installed the Bat myself about 6 months ago or so, put the cloth protector ring under the terminal connectors, and sprayed both terminals with that red stuff that's supposed to prevent the growth.
I'm going to remove the bat and clean everything up good, but was wondering if there's anything I can do to prevent this from happening again.
I have a grounding kit installed, and the positive lead to the amp for my sub is attached directly to the Pos terminal. It's a tight connection on all points.
Thanks,
Old Feb 16, 2011 | 06:04 AM
MadMax07SL's Avatar
Anybody?
Old Feb 20, 2011 | 04:01 PM
asand1's Avatar
Get a new battery and post pics of your terminals. Your connection is less than optimal and your battery is leaking acid, contributing to the corrosion.
Bad connection + acid = electrolysis.
Old Feb 20, 2011 | 05:14 PM
A.Cordeiro's Avatar
^^ what he said
they sell corrosion stoppers (we use em at work) there cotton circles that are covered in a type of liquid that prevent corrosion.
Old Feb 22, 2011 | 09:33 AM
MadMax07SL's Avatar
Originally Posted by A.Cordeiro
That's what I'm saying I used, both products when I installed the new batt about 6 months or so ago...
asand1, you're suggesting it's a leak somewhere causing this? Interesting...I'll have to find the receipt and take it back to where I got it. Can't hurt...
Old Feb 22, 2011 | 09:37 AM
phatboislim's Avatar
vaseline, and yes im dead serious
Old Feb 22, 2011 | 09:48 AM
TunerMaxima3000's Avatar
^ what he said. I'd use dielectric grease cause its cheap, and stays on longer, but they will both perform pretty much the same task.
most common causes for corrosion are worn terminals, dirty connections and dirty batteries, and leaking batteries
Old Feb 22, 2011 | 10:52 AM
Tommiekatt916's Avatar
+1 works i do it every winter
Old Feb 24, 2011 | 10:46 AM
Mr.Nismo_215's Avatar
yeah vaseline will work
Old Mar 11, 2011 | 02:20 PM
kiecas17's Avatar
wd-40 yo
Old Mar 11, 2011 | 09:33 PM
Andrew's Avatar
Vaseline, navel jelly (if thats what I remember reading), those corrosion stoppers, or anti-corrosion spray. Its this purple spray, I spray it on the terminals and its corrosion free all year round.
D Mason
Jun 21, 2016 04:43 AM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
maxima297
Sep 30, 2015 03:32 PM
