Battery ?s
Old Feb 15, 2011 | 06:38 AM
athens6's Avatar
Battery ?s
Currently Im runnin 2 RE SE 15s with about 2400 watts rms ..Got everything wired to 1ohm.. I was lookin to upgrade batterys (After I do the Big 3 upgrade) . Also Im on the stock alternator.. I dont have huge light dimming issues but notice that when the bass hits hard, my voltage drops to about 9 to 11 volts!
Would a kinetic HC800 be enough for my system? Or Should I go Bigger? Im not looking to run more than 1 batt but simply upgrade the one i hav.
Old Feb 16, 2011 | 12:01 PM
Ricksi30's Avatar
There is no way you are dropping that low without your lights dimming. If you want that much power you will most likely need to buy a ho alternator. Adding batteries without having the right alternator to charge them isn't going to help.
Old Feb 16, 2011 | 03:54 PM
Car Addict's Avatar
Old Feb 17, 2011 | 05:57 AM
J2songz's Avatar
Have you tried an Optima
Old Feb 17, 2011 | 10:31 AM
Batxel's Avatar
blah
9volts is pretty damn low. I'm surprised your car is still on at that point. I would recommend getting an HO alt. Getting a better battery isn't going to fix the issue.
Old Feb 17, 2011 | 11:48 AM
Car Addict's Avatar
This. And I would imagine they're doing damage to the electrical system.
Old Feb 19, 2011 | 08:22 AM
athens6's Avatar
i get a lil bit of dimming inside the car but no dimming of the headlights..The only time it drops to 9v is when there is a constant low low bass note..otherwise it'll drop to about 11. the cars got 120k miles on the stock alt..So i guess now would be a good time to upgrade! thanx for the feedback
Old Feb 19, 2011 | 03:26 PM
metallic97gxe's Avatar
Master Will
calculator what amp do you have?, how many fuses are in it? you need to calculate your amperage draw a bigger alty is a good idea but it will have to custom wound they don't make an aftermarket ho for Maxima's
Old Feb 21, 2011 | 07:21 AM
athens6's Avatar
Thanx for the calculator..
Ive got an alphasonik PMA 1200DA..Im not sure about how many fuses it holds
Old Feb 21, 2011 | 04:13 PM
Master Will
just look at the fuses on the amp and see how many you have
Old Feb 23, 2011 | 05:39 AM
HMAX08's Avatar
There is a company that makes an ho alty for the max. I remember a member here buying one. I will search and post link later as I am on my phone
Old Feb 23, 2011 | 05:44 AM
HMAX08's Avatar
https://maxima.org/showthread.php?t=...ght=Alternator
Here is that thread
Old Feb 23, 2011 | 07:41 AM
BOOTZ's Avatar
I had a 200 amp alternator on my 6.5 gen from excessive amperage. Talk to Nate, he's a good guy.
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
markevans999
Sep 10, 2015 04:29 PM
