Amp overheating - suggestions?
Old Jun 19, 2011 | 04:51 PM
Dougy Trah's Avatar
My amp is getting incredibly hot from being in my trunk in pounding so hard (I'm sure you all are familiar), so much so that it broke one of the solder joints inside of the amp and I needed to re-solder it for the amp to work again. Anyway, I can barely turn my volume up past half without my subs cutting out every 5 seconds. I guess thats because it has the overheat protection thing or whatever. Any suggestions on how I could cool the amp down?
*note*- I'm obviously not very good with electronics, and my system is definitely nothing to brag about
Old Jun 19, 2011 | 10:39 PM
Ricksi30's Avatar
What kind of amp? And does it do it when you first start it up?
Old Jun 20, 2011 | 09:02 AM
Goomz's Avatar
you can get a more powerful bass amp. or turn that gain down, or get a decent size 12v fan that you can get from a computer store, and add a relay and tag it to the remote wire, so it draws some heat away from the amp.
Old Jun 20, 2011 | 09:16 PM
locknuts27's Avatar
Over heating amp
Before we can troubleshoot the problem: What is your set up?
Amp brand and wattage
Subs (how many, impedance load)
Wire size, etc, etc....
Old Jun 26, 2011 | 09:15 AM
locknuts27's Avatar
Did you fix the over heating problem?
Old Jun 27, 2011 | 07:59 AM
Maxine02GLE's Avatar
Sounds like your subwoofers are configured at an impedence too low for your amplifier to handle. Check the specs of your amp...your subs may be too much for the amp to handle in their current configuration. Are they bridged and at what ohm? Start there. The amp is getting hot for a reason, most of the time is overexertion...
Old Jun 29, 2011 | 11:23 AM
Matt93SE's Avatar
STFU n00b!
+1
need to look at the system as a whole before you can make any decisions.
unless it's one of the old school Orion HCCA amps that can run a 1/2 ohm load all day long. and even then, they'd get hot as hell too...
Old Jun 29, 2011 | 11:29 AM
Goomz's Avatar
no reply from the op yet. so heres what i would do. get the biggest bag of ice possible, get some wood, and use the wood to prop the ice bags up...pile it on the amp. let it melt all over the amp. that'd keep it cool.
Miket2006
Mar 1, 2021 03:55 AM
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Redfox
Sep 28, 2015 10:41 AM
