Is this wiring correct? (Subwoofers & Amplifier)
Old Sep 19, 2011 | 06:32 AM
kroze's Avatar
I want to bridge my subwoofers and run them in parallel mode and wonder if this is the correct way to do it. If so, does this mean that I'm running the amp at 2ohms instead of 4ohms?
Old Sep 19, 2011 | 07:31 AM
djkevinnn's Avatar
Yes, that would make it into 2ohms, however, make sure your amp is bridgeable down to 2 ohms, or that it is a mono block amp or else you'll run into issues like over heating or it going into protect mode
Old Sep 19, 2011 | 08:54 AM
Ricksi30's Avatar
They're SVC subs, and what amp?
Old Sep 19, 2011 | 02:25 PM
kroze's Avatar
They are MTX jackhammer single voice coil 100-200watts.
Amp is MTX 405 5 channels amp.
http://store.mtx.com/caraudio/archive/thunder405.cfm
For some reason the sub is not hitting as hard even though the new amp (mtx 405) is putting more power out than the old amp i used.
Is this a symptom of poor grounding (I used a different grounding point when installing the new amp)? If my new amp is putting out more power, shouldn't the subs hit harder? Yes I've adjusted the gain, equalizer, and freq but to no avail.
Old Sep 20, 2011 | 11:00 AM
kroze's Avatar
I found the problem, the new amp doesn't put out more power than the old. Problem solved.
Old Sep 20, 2011 | 11:40 AM
djfrestyl's Avatar
Suspension Yoda
For future reference:
http://www.crutchfield.com/S-5jjvc9C...rs_wiring.html
litch
123
Jan 4, 2024 07:01 PM
leatherneck
Sep 30, 2015 09:16 PM
sliptap
Sep 30, 2015 05:57 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
