2004 Maxima Aftermarket Radio Install
Old Feb 23, 2012 | 08:21 PM
tothemax3's Avatar
Ok, I've found the dash kit i need to mount the head unit but how do i connect the head unit to the existing bose system?
Dash Kit:
Metra 99-7404
Also, this unit's install manual shows the tape deck and CD player being removed, what do you do with the plug that you disconnect from it?
Old Mar 4, 2012 | 07:26 PM
installer's Avatar
hi you have to by an aftermarket harness that you wire to the radio harness plus an antenna adapter plug it in all other plugs from the radio just tuck behind
Old Apr 2, 2012 | 06:23 PM
jsantoslive's Avatar
Will the display still work for temperature control and maintenance ?
Old Apr 2, 2012 | 06:44 PM
AscendantMax's Avatar
yes, they will still work. you just lose the portion of the display showing radio info and what-not.
Old Apr 2, 2012 | 08:53 PM
THANKKKKK YOUUUU I have been trying for hours to get a straight answer on this! Im fine With losing track info on screen bc that will be on the new deck just want to make sure temperature control and clock and all that still show up
Old Apr 2, 2012 | 10:38 PM
not a problem
the maintenance, clock, and A/C stuff will still work.
Old Apr 21, 2013 | 09:04 PM
Jenn7xo's Avatar
Okay I think I'm asking what you were asking lol I want a aftermarket radio I have an 04 maxima but I want it to replace where my current screen is but I want my air and maintenance to be on that screen I don't want to have multiple could y'all suggest a brand please thanks so much!!!
Old Oct 15, 2013 | 02:43 PM
BRich157's Avatar
Would the screen still work if you have an 06 with navi? I been trying to get a straight answer on that but nobody can tell me
Old Oct 16, 2013 | 09:24 PM
w8lifter21's Avatar
Climate controls do not run through the radio on Nissans so if you swap the radio they'll still work.
Old Oct 18, 2013 | 12:32 PM
BRich157's Avatar
I got it hooked up but now no sound. This sucks man!
Old Oct 18, 2013 | 02:24 PM
w8lifter21's Avatar
Do you have bose? If so did you connect the amp turn on wire off the aftermarket deck to the amp turn on wire that hopefully you are using to install the radio? Should be a blue wire.
Old Oct 18, 2013 | 05:21 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Should be Blue/White. Blue is antenna.
Team STILLEN
Aug 10, 2015 04:29 PM
MikesChevelle
Aug 10, 2015 11:21 AM
MikesChevelle
Aug 9, 2015 11:50 AM
PhalC1
Aug 5, 2015 02:36 PM
