left door speaker blown?
Old Mar 5, 2012 | 07:20 PM
kyochang's Avatar
hi, I have a 4th gen maxima with the bose system.I recently replaced the stock speakers because it would only play on the driver side speaker. When it first got the aftermarket hu installed, all the speakers worked, but recently I heard that the driver side speaker wasnt working. All the other speakers work fine, but the driver side is the only one giving me problems. Sometime when i go over a big bump, the sound comes back on for a bit, but leaves once i turn off the car. I was wondering if the speaker is blown or if i should play around with the integration adapter.thanks
Old Mar 5, 2012 | 08:43 PM
AznRyan's Avatar
There's threads dealing with stuff like that. Use the search function for "bose speaker cutout"
Old Mar 5, 2012 | 08:44 PM
AznRyan's Avatar
Since you're new I'll let you know, you should always try to search function first.
This site's been around for a loong time, and there's probably been people with the exact issue you've had. Search and you'll probably find an existing answer, so you won't even have to wait for help.
Old Mar 6, 2012 | 02:13 PM
kyochang's Avatar
sorry bro.didnt know what it was called.
Old Mar 6, 2012 | 03:06 PM
19GLE97's Avatar
aftermarket hu dont really work with stock speakers? that many be your problem
Old Mar 6, 2012 | 03:37 PM
AznRyan's Avatar
It's np. I'm new here too, some people just get really **** about new threads.
Anyways, good luck getting your speaker working!
Old Mar 6, 2012 | 03:54 PM
AscendantMax's Avatar
works fine...if you know what you're doing.
OP, check your wirings on your radio. sounds like something is loose.
Old Mar 6, 2012 | 09:24 PM
installer's Avatar
hi it could be a blown speaker the tinsle lead going int the speaker could be loose where it connects to the cone of the speaker itself
Old Mar 12, 2012 | 02:33 PM
kyochang's Avatar
nope no loose wires, but i found out that the speakers would turn on if i raised the volumes up to around the 20's.know what the problem could be?thanks
Old Mar 12, 2012 | 06:07 PM
installer's Avatar
you have a blown left front speaker usually they ground out at higher volumes but sometimes they can pop on
Old Mar 12, 2012 | 07:43 PM
kyochang's Avatar
okay thank you.so what would you recommend that i do?
Old Mar 13, 2012 | 11:09 AM
installer's Avatar
new set of speakers would be reccomendation
Old Mar 13, 2012 | 03:35 PM
kyochang's Avatar
would any 6.5" speakers work w/ the bose or would i need extra tools?and do i have to change the back speakers too or not?thanks
Old Mar 13, 2012 | 05:15 PM
installer's Avatar
private message me
Old Mar 14, 2012 | 01:14 PM
yeah any 6.5 will work, you'll just need some adaptor plates. it can be easily made out of some 3/4" MDF.
James92SE
142
Jan 2, 2024 09:23 AM
Floktndr
Nov 30, 2015 07:48 PM
lkiller123
Sep 21, 2015 03:00 AM
ajahearn
Sep 19, 2015 03:03 PM
