Sirius Radio for 2007 Maxima 3.5SE
Old Mar 13, 2012 | 08:24 PM
BCGUY2008's Avatar
I know I am going to take flack for posting yet another thread on this topic but if any of the others were clear I wouldn't still be looking for clarification.
I am have 2007 Maxima 3.5SE with the Bose system (no navigation). Picture is attached.
Can I simply add a tuner and have it wired to this Bose system to access Sirius through the headunit? Where can I find one?
Old Mar 14, 2012 | 05:52 AM
installer's Avatar
hey man whats going on you could you a pac-audio piece to work sirius through the radio or even an i -simple piece Part Number:ISNI11
from pac-audios website
Old Mar 18, 2012 | 09:21 PM
DAlastDON's Avatar
I do not think you can with your head unit. I do not see a "SAT" button.
Old Mar 19, 2012 | 05:53 AM
installer's Avatar
after lookking at the web site its states "Radio must have a "SAT" button or have "CH", "CHANNEL", "CAT" or "CATEGORY" printed somewhere on the face of the radio to be compatible" witch if you look at the bottom right of the radio it has CAT-Folder written it is a compatible radio just the very basic one
Old Mar 19, 2012 | 10:41 AM
DAlastDON's Avatar
I agree with ya now after looking at the audio section in the car manual. It says that the SAT function is available by pushing the radio button.
FM/AM/SAT radio operation
FM/AM/SAT band select:
Pressing the RADIO button will change the band as follows:
AM ←→ FM ←→ SAT (satellite, if so equipped) When the RADIO button is pressed while the ignition switch is in the ACC or ON position, the
radio will come on at the station last played.
No satellite radio reception is available when the RADIO button is pressed to access satellite radio stations unless optional satellite receiver and antenna are installed and an XM® or SIRIUS™ satellite radio service subscription is active. Satellite radio can only be installed in vehicles that were factory pre-wired for satellite radio. Satellite radio is not available in Alaska, Hawaii and Guam. If satellite radio is not operational then the RADIO button is used to toggle between AM and FM bands
Old Mar 19, 2012 | 06:20 PM
installer's Avatar
you cant access the sat without havin something hooked up wont go into it if you add a piece like the piece i showed you it activates it in the radio
Old Mar 25, 2012 | 06:26 PM
BCGUY2008's Avatar
Thanks for the replies. So does that mean this Maxima is pre-wired for satellite and all I have to add is the Sirius Tuner and antennae?
Old Mar 25, 2012 | 07:33 PM
installer's Avatar
you have to get the pac audio gateway piece and then a sirius kit pm me ille explain more
Maxilano
Aug 31, 2015 07:33 PM
carguy96
29
Aug 21, 2015 02:43 PM
98nismomax
Aug 13, 2015 12:44 PM
MikesChevelle
Aug 9, 2015 11:50 AM
