I Need Advice From The Audio Gurus
Old Apr 22, 2012 | 07:45 PM
officerfrasher's Avatar
So after installing my new MTX subs, I'm thinking about getting a new amp to run them. The problem is, I SUCK AT A/V STUFF! I can install it, but I have no idea what pieces to put together to install! I currently have an MTX 4 channel amp, I don't remember what watt it is. The new subs I installed are MTX Thunder 5500. The paper says the recommended power rating is 100-200 watts RMS. They have dual 4 ohm voice coils.
I think I'm wanting to get a 2 channel amp that would run the subs between the 100-200 watts that is recommended. HELP ME PICK OUT AN AMP! I'm sure I can't afford something as good as JL, but maybe something along the lines of another MTX or a Rockford Fosgate. Thanks!
Old Apr 23, 2012 | 04:35 AM
IDvsEGO's Avatar
For a dual 4 ohm sub i suggest getting a mono channel amp. They are purpose built for subs so you usually get more wattage for your money. 100-200 is fairly entry level for that type of amp. You should be able to get kicker, Rockford, alpine, and several others at pretty good prices. Do you have a specific budget?
Old Apr 23, 2012 | 11:17 AM
Budget would be $200 or less.
Old Apr 23, 2012 | 07:12 PM
IDvsEGO's Avatar
bah, I just re-read you post and noticed you had 2 subs. I thought it was just one. You were on the right track with the 2 channel. You could wire the subs to present a 2 ohm load to each channel ot a 4 ohm load to the bridged. Should net the same power from most amps just depends on which you would rather cable up. I dont like subs wired in stereo personally.
I ahd already pasted all of these so maybe use them as reference for 2 channel amps. until I can look at 2 channel suggestions. all these are amps that I would feel comfortable spending my own money on...
http://www.sonicelectronix.com/item_...PI-S270.1.html
http://www.sonicelectronix.com/item_...io-RT250D.html
http://www.sonicelectronix.com/item_....1-CO5001.html
http://www.sonicelectronix.com/item_...ME-R250-1.html
http://www.sonicelectronix.com/item_...-BK650.1D.html
http://www.sonicelectronix.com/item_...12PX200.1.html
http://www.sonicelectronix.com/item_...11DX250.1.html
http://www.sonicelectronix.com/item_...I-S550.1D.html
http://www.sonicelectronix.com/item_...10ZX300.1.html
http://www.sonicelectronix.com/item_...o-JX250-1.html
Old Apr 24, 2012 | 12:34 PM
I'm considering this amp: http://www.crutchfield.com/p_236TH65...650.1&skipvs=T I can get it on eBay/Amazon for under $200.
Old Apr 24, 2012 | 07:27 PM
IDvsEGO's Avatar
that would work. I have an mtx 6500d that is probably 7 years old, still works fine.
Old Apr 24, 2012 | 08:16 PM
DAlastDON's Avatar
You went with an infinite baffle setup, right? The amount of power that you are going to need is going to be less than if the speaker was in a box. The amp you selected is a perfect match if the subs were in a box but i think it would work. Wire the coils in a series/parallel configuration to achieve four ohms. Start with the gains down all the way when tuning and make sure to turn on the sub-sonic filter on the amp.
Old Apr 24, 2012 | 09:31 PM
Question - so the amp says it'll push 650 x1 @ 1 ohm. If I use 2 subs does that mean they'll both get 325?
Old Apr 25, 2012 | 05:47 AM
installer's Avatar
what kind of box are these subs in
Old Apr 25, 2012 | 09:04 AM
No box. Open air/infinite baffle set up.
Old Apr 25, 2012 | 05:50 PM
AscendantMax's Avatar
The subs will handle WAY less power in an IB configuration. You don't need a powerful amp to drive free air subs.
Old Apr 25, 2012 | 06:59 PM
You're the man I was looking for! Pick me out an amp for under $200 PLEASE!
Old Apr 25, 2012 | 09:37 PM
DAlastDON's Avatar
ROFLMAO....
I like these. Bridge it and put a 4ohm load on it.
http://www.sonicelectronix.com/item_...ch-P300-2.html
http://www.sonicelectronix.com/item_...-XTA-2160.html
http://www.sonicelectronix.com/item_...-1600.2V3.html
http://www.sonicelectronix.com/item_...-ONX2.100.html
http://www.sonicelectronix.com/item_...009-Model.html
Connect the subs like this.
http://m.seimg.net/product/img/subwo...ch_bridged.jpg
Old May 4, 2012 | 11:52 PM
but yeah any of those amps will work.
Mahmuth
Aug 16, 2024 08:23 PM
gigabyte
Jan 6, 2017 06:05 PM
Fbana41
Aug 29, 2016 12:18 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
