Another Bose Question
Old Apr 30, 2012 | 03:38 PM
cjones450's Avatar
ok well i have an 03 se with bose package im planing on changing all 4 speaks and running a 4 channel amp for my mids and highs. Can i just change the speaks and use a non bose harness to run my own amp?
Old Apr 30, 2012 | 07:15 PM
installer's Avatar
all you will need is 12 volts accesory and a ground behind the radio you can unplug the stock amp or remove it and get all your wires there
Old May 2, 2012 | 06:25 AM
cjones450's Avatar
Run the accessory and ground to the radio? Or my mids and high's amp?
Old May 2, 2012 | 07:08 PM
installer's Avatar
accesory ground and 12 volts to the radio and us an amp kit for the amp also will need to run rcas and remote lead to the amp from the radio
do you need it installed would that be easier for you
Old May 3, 2012 | 07:07 AM
cjones450's Avatar
No ive been installing radios and systems on the side for almost 7 years ive just never messed around with the bose stuff
Old May 3, 2012 | 05:44 PM
installer's Avatar
its all the same stuff bose is just a name brand if you need wire colors for the car i can get them for you
Mar 12, 2020 12:06 AM
pears
Sep 18, 2015 05:25 AM
popdedop
Sep 11, 2015 11:17 AM
Johnny9595
Sep 3, 2015 05:18 AM
